20 Most Recent
Simplicity Quilt 'n Craft S05 Mechanical Sewing Machine Questions & Answers
Simplicity so5 needle wont move
There is a device on the right side of the machine to make this work. It is either a knob to turn or a plate to push in. It is located on the right side of the machine in the wheel that turns when the machine is running. This is used to wind a bobbin. The needle doesn't run when the bobbin winder is being used,
Why does my Simplicity American Quilter SA2400LX only stitch straight now? The stitch selector works correctly, but only stitches straight.
There are a few possible reasons why your Simplicity American Quilter SA2400LX is only stitching straight:
- Stitch length setting: Check that the stitch length setting is not set to zero or a very small number. If it is, the machine will only sew straight stitches.
- Stitch selector mechanism: It's possible that there is a problem with the stitch selector mechanism that is preventing it from engaging properly. You may need to take it to a repair technician to have this checked and fixed.
- Tension setting: Make sure that the tension setting is correct for the type of stitch you are trying to sew. If the tension is too high, it can cause the machine to only sew straight stitches.
- Timing: The timing of the machine may be off, which can cause the machine to not properly engage the stitch selector mechanism. This is a more complicated issue and may require professional repair.
If you are comfortable with sewing machine repairs and want to try to fix it yourself, start with checking the stitch length and tension settings. If those are not the issue, it may be best to take it to a repair technician for further diagnosis and repair.
