20 Most Recent
Holmes Products POH2501 Oil Filled Radiator Heater Questions & Answers
It is about 6 years old, and it was in the storage
On those heaters it is very normal for the cord to get warm. And you should never use an extension cord with them unless it is at least a 12ga. wire....almost all normal household cords are way too light and that will cause both cords to get hot....
Also if the Power Co. has the voltage lower it will also cause the cord to heat up, cause as the voltage goes lower the amps. go up....
I would say that there is nothing wrong with your heater, just that you used an extension cord which you should not do and also may have hit a time of low voltage...
also expect that for the cord to get warm is very normal.....they pull alot of power when heating...
heatman101
Patton POH2501
take a hole punch and knock a hole in each end, one on the top, one on the bottom and drain the oil into a 2 litre plastic bottle. Now you can recycle both!
Not heating
Sounds like either the thermostat or the element. If you hear a clicking when you rotate the thermostat you can assume that it is working. My advise is to replacethe heater. The element is sealed inside the oil chamber and the thermostat will cost almost as much as a new heater, sorry.
Need wiring diagram
Wiring diagram for a 3-way switch, one of the many wiring diagrams showing different methods of wiring a three way switch circuit. This electrical wiring diagram shows power into light switch Box #1 – wire to light from switch box #1, and from switch box #1 to three-way light switch box #2.
My oil filled heater is making a buzzing noise every 15 minutes or so what wrong with it?
Probably the thermostat contacts have become worn and a certain amount of arcing is happening when they close.
Replacement thermostat units used to be easy to change and were readily available for quality domestically manufactured oil filled radiators but these days it would probably be cheaper to buy an imported heater. You wouldn't lose by asking your local supplier and if they are still available check the internet price.
It would be wise to check the wiring and internal connections before junking it.
Space heater stopped working
First, check the warranty to see if it still in effect. I suspect a bad contact, broken control or problem with the heater element connections. If there is no physical damage from being dropped, tripped over, etc., then something like this would be a manufacturing defect (premature failure). If it's out of warranty, and you know how to use a multimeter, you could unplug the heater and start checking the continuity of the parts and wiring inside.
