20 Most Recent Brother PED Basic Card Writer Box & Embroidery Magic II for PC Questions & Answers
Windows 8 doesn't recognize my PED design card writer
Go to the website and find your product to download a driver: PED Basic United States Brother Solutions Center
4/15/2014 5:16:49 PM • Brother PED... • Answered on Apr 15, 2014
I have a Ped-Basic and
The PED-Basic should only be installed with the driver and the software from Brother: http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/dlfh/000000/000100/dlfh000107.html?reg=us&c=us&lang=en&prod=hf_basiceus&type2=47&os=99&flang=91&dlid=dlfh000107 .
Since you've attempted to install the software from another source, you may have the product partially installed in the Windows registry. This could block a new installation. You can try to uninstall the product with Revo Uninstaller: http://www.revouninstaller.com/revo_uninstaller_free_download.html .
Otherwise, you will need to go through the registry and delete lines related to PED Basic. Make sure to back up the registry before searching it. Start > type regedit into the search box. Then File > Export (choose all and back up to a location other than the c: drive).
Embroidery Magic 2 is not compatible with Vista (or Windows 7). For more information, try contacting the creators via the contact at: http://www.auntymdesigns.com/html/software.html . The work-around is to use the software is a second machine with an older version of Windows. This can be a real computer, a dual boot computer or a virtual computer. For most of these you need a valid (licensed version) of the older Windows OS and the virtual computer program (for the last option). The exception is that Virtual PC and XP mode can be installed for free on computers running Win7 Pro or Ultimate. For a virtual computer, you will not be able to have the PED Basic hardware available to both the real and virtual computer. It can be installed on one or the other. Also files can't be shared directly between the real and virtual computer. They need to be saved to external media (optical media or external drive).
However, the installation of the software or hardware in a virtual computer is the same as any software install on a real computer.
I hope this helps.
(alternatively, you can upgrade your software. See the auntymdesigns site above.)
1/4/2011 1:06:13 AM • Brother PED... • Answered on Jan 04, 2011
I transfer the pattern to
I've just had the same problem and found that you need to change the size of your hoop down to a smaller hoop size. Hope that works for you!
9/5/2010 7:44:22 AM • Brother PED... • Answered on Sep 05, 2010
I have plugged it in but don't know what to do
HI irenepaine. I've installed this once and I know it could be a little tricky because you need to use the software to convert whatever design you want - from JPEG to the machine's type. Then you use the card to save the file and then connect it to the sewing machine and then, using the display select the file you want. You need to use like 2 different software to acomplish this. Also you can do it thru the USB cable. Since I can't remember - I'm sending you the brother support site. Please find the correct model and see if it helps.
http://welcome.solutions.brother.com/bsc/public/Model_list.aspx?reg=us&c=us&lang=en&titleid=36#pe
Please dont forget to rate and provide positive feedback for our free support today. Thank you :D
4/29/2010 1:19:06 PM • Brother PED... • Answered on Apr 29, 2010
I have used my card many times but today when I
the card may be bad or damage or the card reader is bad or it is damage
4/24/2010 2:01:21 PM • Brother PED... • Answered on Apr 24, 2010
I have downloaded the ped-basic
it sounds like you may have a driver problem and possible the installation was not done properly. I would say. uninstall whatever you download and start from scratch as follows:
if you DO NOT have vista or windows 7 do this follow the instructions to install the sofware from the the manual
if you need to download the sofware in case you don't have the cd you can download the updated sofware from here
if you DO HAVE vista or windows 7 you need to download the software package from this page just go to the bottom and you'll see section for your operating system
1/16/2010 7:16:43 PM • Brother PED... • Answered on Jan 16, 2010
I have windows vista and have downloaded the
right click on icon click properties and set to xp
1/7/2010 8:47:18 PM • Brother PED... • Answered on Jan 07, 2010
3answers
Using Brother PED Basic to
Hi.
Try using a different card. If the card is damaged it may not be read in the sewing machine.
Also , the card should be compatible with Babylock, but give them a call just to ensure there is no particular issue with this model. you find their number on the Babylock owner manual.
If the design is being saved, software should be OK, you can try reinstalling software and plugging the PED to a different USB port, but I don't think it will make a difference.
Test a different card to check if the card is faulty, if you do not have one, contact Brother.
10/27/2009 10:36:04 AM • Brother PED... • Answered on Oct 27, 2009
How to do toner reset in brother HL-L5210DW and HL-L6210DW ?
https://www.youtube.com/watch?v=jux8VY4Ibvc More information on the brother web site.
1/17/2024 8:02:14 AM • Brother... • Answered on Jan 17, 2024
Tengo una maquina de escribir Brother ML300 y tengo el problema de que no borra las letras. La cinta de borrar es nueva. La tecla de borrar golpea pero no borra- Mi nombre: Miguel Prato
Hola, Miguel. Si tu m?quina de escribir Brother ML300 no est? borrando las letras correctamente incluso con una cinta de borrar nueva, puede ser que haya alg?n problema con el mecanismo de borrado en s?. Aqu? te dejo algunos pasos que puedes seguir para tratar de solucionarlo:
  1. Aseg?rate de que la cinta de borrar est? correctamente instalada en la m?quina. Revisa que la cinta est? colocada en la posici?n correcta y que est? bien ajustada.
  2. Verifica si la tecla de borrar est? obstruida o atascada. A veces, las teclas de borrado pueden quedar bloqueadas por restos de papel o suciedad. Puedes intentar limpiar suavemente la tecla y el mecanismo de borrado para ver si esto soluciona el problema.
  3. Comprueba si la cinta de borrar est? correctamente ajustada. A veces, si la cinta de borrar no est? ajustada correctamente, puede no funcionar correctamente. Aseg?rate de que la cinta de borrar est? bien tensada y que el mecanismo de borrado la est? tocando correctamente.
  4. Si los pasos anteriores no solucionan el problema, es posible que haya alg?n problema en el mecanismo de borrado en s?. En ese caso, podr?a ser necesario llevar la m?quina a un servicio t?cnico para su reparaci?n.
Espero que estos pasos te ayuden a solucionar el problema con tu m?quina de escribir Brother ML300. ¡Buena suerte!
3/3/2023 10:16:04 PM • Brother... • Answered on Mar 03, 2023
2answers
Turn off Sleep Mode on Brother HL-2170W
there is no sleep mode. set up is done under printers. You will need the Cd that comes with printer. Call Brother for one. https://download.brother.com/welcome/doc002308/cv_hl2140_usaeng_usr_d.pdf
3/30/2022 8:11:54 PM • Brother... • Answered on Mar 30, 2022
What is the fastest way to evict someone
The answer varies state by state, even in the time of coronavirus. Bear in mind if your brother left without notice, neither you nor what party he brought into the home knows when or whether he will return. It is neither your fault nor that of the remaining party that the brother abandoned them in such circumstances. Just what resources they can tap for accommodations readily probably depends upon their personal resources, that of the city, or that of the state. Chances are your bother took the only transportation immediately available to the party left behind. The party left behind probably is waiting for the brother to return but if that is not likely to happen, they most likely will need a bus ticket to some other destination. Just where they get that might be a matter for a social worker to advise; such a party might know where temporary shelter might be. Whether or not the county attorney's office can advise, I am uncertain. In a rural area, a county judge might have some discretionary funds for a ticket. Local municipalities tend to like to move the problem elsewhere before it becomes a perpetual burden. https://evictionlab.org/covid-eviction-policies/ https://ipropertymanagement.com/laws/eviction-process
11/20/2021 5:39:05 PM • Brother... • Answered on Nov 20, 2021
How do you disassemble the brother ce8100? To replace the lcd screen.
No longer available
6/3/2021 4:50:45 PM • Brother... • Answered on Jun 03, 2021
What is Step by step guide to fix Brother hl-l2360dw Wireless Setup?
https://www.youtube.com/watch?v=4NkzmVdkweM To set up your Brother machine on a wireless network:
  1. Connect the power cord to your Brother machine and then connect it to an electrical socket. ...
  2. Press Menu button on the machine's control panel.
  3. Press the Up or Down arrow key to select Network and press OK.
  4. Press the Up or Down arrow key to select WLAN and press OK.
https://support.brother.com/g/b/faqend.aspx?c=eu_ot&lang=en&prod=mfcl2700dw_us_eu_as&faqid=faq00100429_000
5/18/2020 6:46:48 PM • Brother... • Answered on May 18, 2020
Junk removed
Please DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website
11/12/2019 9:27:59 PM • Brother... • Answered on Nov 12, 2019
BROTHER PRINTER TECH SuPpoRt pHoNe nUmBeR #@ {18OOSCAMMER69} RITA USA
FixYa Experts: Once you have reached a certain number of answers, then you can Edit and Delete these spam posts too, so they don't victimize unwary users. By my estimate, 4 of your fellow volunteer Experts are currently deleting 5000 or more spams per day, and it's not keeping up with the flood. Please help us out.
11/11/2019 7:11:49 AM • Brother... • Answered on Nov 11, 2019
BROTHER PRINTER tech suPpOrt pHoNe {+1^8OO8O3^1O69-} nUmBeR j USA
FIMLOCEKNO, Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
11/9/2019 6:33:01 PM • Brother... • Answered on Nov 09, 2019
Brother PED Basic Card Writer Box & Embroidery Magic II for PC  Logo
Popular Tags
53 questions posted
Top Brother Computers & Internet Experts
Ngoro
john h
Are you a Brother Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Brother Computers & Internet
Most Popular Question
windows vista downloaded
  • Computers & Internet
