20 Most Recent
POLARIS SOFTUBE QUICK CONNECT - P-133 Questions & Answers
Softub about 4 years old - I have a leaking water
Thank you for posting your question here on Fixya.com.
Neither...it is threaded onto the motor shaft. Lock the shaft at the end opposite the impeller and turn it off counter clockwise.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
The wall fitting seems to
Is the fitting insert missing or do you still have the insert but the tabs are broken off? Either way, you can get the replacement and thread it into the wall port. You may have to remove whatever is left of the damaged insert first. The part is called the Universal Wall Fitting, part number 650000. They are about $5 at a local pool store.
John
