20 Most Recent Epic 450 Mx Treadmill Questions & Answers
0answers
Treadmill flips breaker after staring up for about a second?
An overload causes the breaker to open. First: The motor might have a bad field winding or internal partial short: Second: A bearing on one of the rollers may be shot? You can check for this by simply walking on the tread. It should move, if not there is a bad bearing. A far out reason is that the breaker is opening at less than rated current. (failed breaker). If you have a long heavy duty extension #16 gauge wire (18 gauge minimum), try another outlet that you know is on another breaker.
2/2/2015 6:34:36 PM • Epic 450 Mx... • Answered on Feb 02, 2015
How far is a mile in distance numbers
1.6km =1,600meters.
8/1/2012 12:55:06 PM • Epic 450 Mx... • Answered on Aug 01, 2012
Epic 450mx console lights up but nothing works not even the fan, worked fine yesterday
1) Adjust the REED switch,clean, and tigh the connector wires.see the diagram attached.2) See inside for any fuse blown adn replace, or c.breaker reset3) Reset the machine. Tight any connector, and wires looses, or breaker use the DVOM , see the diagramGod bless you5_9_2012_10_27_15_am.gif5_9_2012_10_27_42_am.gif5_9_2012_10_28_07_am.gif
5/9/2012 10:28:22 AM • Epic 450 Mx... • Answered on May 09, 2012
Turns on but will not respond when keys are pressed
Dear Sir:As you must understand the treadmill use the most advance electronic design.Please do the following:1)use contact cleaner(radio schack or whatever)2)Inspect the fuse.3)Tight the ribbon cable INSIDE from the keypanel(not the console)4)Tight the connector from the console going to the main board motor.check this block diagram for to see if anything can help you in the treadmill. If you do not resolve your problem. can be board console vs . main board motor.2_14_2012_7_36_06_pm.gifGod bless you. sincerely.ernesto a cuadramanagua, nicaragua
2/14/2012 7:36:36 PM • Epic 450 Mx... • Answered on Feb 14, 2012
Need large picture of reed switch under hood. can't locate with printed instructions
sincerely.Merry Christmas.ernesto cuadra managua, nicaragua2q==
12/24/2011 4:46:20 PM • Epic 450 Mx... • Answered on Dec 24, 2011
Display functions on right side don't work as
Hi drnelson3,
This problem is as a result of a bad control panel. The control panel controls all the functions of the unit it accepts commands and executes them. Often times it would accept a command but not execute as a result of malfunctions on the control board. This is why a times it comes on and doesn't function. The control board is not totally bad but suffers from partial failure therefore the problems.
Best solution is to get the control board replaced this can be done by any service repair personnel or simply contact the nearest dealer for a repair person.
Hope it helps.
Thank you for using FixYa.
8/29/2011 10:08:09 PM • Epic 450 Mx... • Answered on Aug 29, 2011
Motor has been checked ok when is turned on it
You must see with a volt meter, if you are getting arequired power. It can be weak motor or defective motor controller issue. The interiormotor links are loose or the belt is dried up use some basic lubing by grease.If the problem still exists then you may need to replace motor controller ormotor.
5/10/2011 1:11:09 AM • Epic 450 Mx... • Answered on May 10, 2011
My Epic 450 squeaks so
sounds like the belt needs lubricating or perhaps the moving parts inside.
4/9/2011 4:13:21 PM • Epic 450 Mx... • Answered on Apr 09, 2011
Epic 450 Mx Cannot adjust speed/programs and only
the console's keypad overlay is bad and the console will need replaced
8/13/2010 6:15:14 PM • Epic 450 Mx... • Answered on Aug 13, 2010
Console to elevate and control
you will need to test the red wire coming to the console with a volt meter to see if you are getting the required 9-12 vdc if you are replace the console, if not replace the controller. Now if just the buttons are not working replace the console. You can get a console from iconservice.com
8/13/2010 6:09:50 PM • Epic 450 Mx... • Answered on Aug 13, 2010
Epic T60 treadmill motor on 1-2 sec. then go off
Here are a few things you can try to troubleshoot the issue:
  1. Check the power supply and make sure that the treadmill is plugged in and receiving power.
  2. Check the fuse or circuit breaker to make sure that the treadmill is not tripping any electrical circuits.
  3. Make sure that the motor and controller are properly connected and functioning correctly. You may want to check the wiring and make sure there are no loose or damaged connections.
1/2/2023 10:33:17 PM • Epic Exercise &... • Answered on Jan 02, 2023
How to troubleshoot and repair monitor on EPIC 420R recumbent bike?
Question edited. Wrong type of peddle/pedal :>) See if you can get in behind the monitor and look for a fuse on the motherboard to it. The manual gives a bit of routine maintenance information and it does has a full parts schematic with contact to Icon Health and Fitness, the distributor for spares. https://www.manualslib.com/manual/568149/Epic-420-R-Bike.html?page=17 https://www.google.com/search?q=troubleshoot+and+repair+monitor+on+EPIC+420R ..
1/12/2022 8:34:20 PM • Epic Exercise &... • Answered on Jan 12, 2022
I am trying to connect my epic a35t to home Wifi, but touchscreen is not working
This appears to be a Treadmill rather than a Tablet / eReader? Category moved to Epic Treadmill. It appears to be a known issue and there are various fixes including reinstalling the Android Operating System for the display. https://www.google.com/search?q=epic+a35t+reset ..
12/1/2021 5:42:02 PM • Epic Exercise &... • Answered on Dec 01, 2021
Epic 450 Mx Treadmill Logo
23 questions posted
Top Epic Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
Sportsmith LLC
Sportsmith LLC
Don A
Don A
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Epic Exercise & Fitness
Most Popular Question
epic 450 mx cannot adjust speed programs
  • Exercise & Fitness
