20 Most Recent Unknown ASUS N56VJ-WH71 15.6" Premium Audio Laptop with 3rd Gen Intel Core i7- Questions & Answers
ASUS N56VJ BEEPING
Saltrock the beeps you hear are BIOS Beep CodesThe computer's way of telling you something is wrong, and an area to look into for it.The beeps come out in a codeMay be a long beep, then a pause followed by 2 short beeps.May be 2 short beeps, a pause, then it beeps 2 short beeps, pause, and all over again.You get the pictureNow in your best recollection just state the facts sir...............What?I mean what beep code so you hear Saltrock?Post back in a Comment.While I wait.............1) Remove ALL power. Remove the AC adapter (Charger), and Battery.(If you have the laptop hard wired to your router, unplug the cable from the laptop)2) Laptop closed turn it over, Battery Compartment facing Away from you.Remove the large panel on your side. Looks to be one single Philips head screw to remove/loosen.Lift the Harddrive/Ram Memory Compartment Panel, up on the screw side at an ANGLE.There are TABS on the panel on your side, that go into the Base Enclosure. (Bottom Cover)Move the panel a little towards the Battery Compartment, and remove.The Ram Memory module/s ('Stick') are held in by two spring clips on each side.Closer inspection will reveal the spring clips have a protrusion, or 'Bump' on them.These bumps fit into Side Notches, in the Ram Memory module.Simply ease one spring clip to the outside. Be gentle.The spring clip only needs to move far enough, for the 'bump' to clear the Side Notch.Now do the same for the other spring clip.When both spring clips are eased to the outside, the Ram Memory module will 'spring up' a little bit.The BODY of the Ram Memory module, is everywhere on it, EXCEPT the gold plated contact pins on the bottom.The Body is coated with a see-through protective plastic.Handle the Ram Memory module by the BODY.See the angle that the Ram Memory module popped up to?Remove the Ram Memory module AT THAT ANGLE.Reinstall the Ram Memory module at the same slight angle.Failure to comply, can damage the gold plated contact pins on the Ram Memory module, and/or the contact pins in the Ram Memory slot.When reinstalling insert at an angle, and fully inserted into Ram Memory slot. Then gently press down on the side that is tilted up; until the spring clip bumps pop into the Side Notches. (Of the Ram Memory module)Note that there is a Locating Notch, on the Bottom of the Ram Memory module. (Where the gold plated contact pins are),http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.pngMake sure you line the Locating Notch of the Ram Memory module, up with the Locating Lug in the Ram Memory slot.The Ram Memory module only goes in ONE direction.What I would like you to do, is remove all Ram Memory modules, and clean the gold plated contact pins.Use a pencil eraser.If you are using an eraser on the end of a pencil, and not a solid eraser; refrain from letting the metal band of the pencil, touch the gold plated contact pins.Rub back, and forth; and up and down. Clean EACH gold plated contact pin. BOTH sides. Doesn't take much pressure, nor rubbing to clean them.Doesn't take much 'corrosion' to make a bad contact, either.(Corrosion in marks because Gold isn't supposed to corrode.Just my term)When finished use air to remove the eraser dust.If a can of compressed air for computers is available use it.If not air pressure from your mouth will be sufficient.Reinstall the Ram Memory module/s.Reinstall the large panel cover.Reinstall the Battery.Reconnect the AC adapter, and then plug it into power.WAIT 1 minute, turn the laptop on.Still no?I await the BIOS Beep Code then.Asus Support > Asus N56VJ series of Notebook PC > Downloads page,http://support.asus.com/download.aspx?SLanguage=en&m=N56VJ&p=3&s=390&os=36&hashedid=2W6oktGQFZdwZ7cPScroll down. Click on the blue + sign, next to the blue Manual (4)Scroll down to Version E6951To the right of - Download from,click on the Blue -> GlobalThis is a PDF file. It is also the User Guide.The computer you are using now has Adobe Reader on it, which uses PDF files.After you click on Global it may take up to 30 seconds, before the first page comes up.Go to Page 64 - Locating the hard disk driveShows you the panel to remove, and where the screw is located.Page 66 - Memory (RAM) does not show you the panel, nor screw.Regards,joecoolvette
2/7/2013 4:04:49 AM • Unknown ASUS... • Answered on Feb 07, 2013
How to connect tablet to tv
basically TABLET PC included HDMI video port. please check that side panel on TAB.2_14_2013_7_18_53_am.jpgOK you found then connect TABLET PC and Television set via HDMI to RCA convertor cable2_14_2013_7_23_12_am.jpgthis is the easy way.
2/14/2013 7:24:34 AM • Computers &... • Answered on Feb 14, 2013
Implementing Reliable WordPress Website Backups: A Solution to Downtime and Errorsi wan
Keep a backup on your hard drive or a backup. The backup system is a free service supplied by your internet provider. If you use it daily or after every update, there will never be an issue.
4/25/2024 6:13:32 PM • Computers &... • Answered 10 hours ago
3answers
WHAT IS THE E MAIL FROM ECO BANK ALL ABOUT
Could be a phishing attempt, unless you have an account with that bank.
4/25/2024 5:54:17 PM • Computers &... • Answered 10 hours ago
4answers
How to Install YouTube DL.py to Download YouTube Videos to my PC?
Actually, you just need the help of a YouTube Downloader. If you still need help, why not try this YouTube/Video Downloader? Leawo YouTube Downloader acts far more than a single online video downloader to download YouTube videos and other online videos from various video sharing sites like Facebook, Dailymotion, AOL, iFilm, Myspace, Dailymotion, etc. Besides the ability to download online flash videos, this FLV downloader could also acts as video download accelerator to speed up online video downloading, video accelerator to speed up video buffering for smooth playback, video player to play back videos, and IE browser to browse online videos for free downloading. It could extract audios out of online videos, like converting YouTube video to MP3. Hope it can be another choice for you or other users. :) Watch online videos offline freely with Leawo YouTube Downloader
4/25/2024 8:54:44 AM • Computers &... • Answered 19 hours ago
What is digital marketing?
Digital marketing, or “online marketing,” is a form of advertising that uses the internet and digital technologies to connect with customers. Digital marketing seeks to accomplish the same thing as traditional marketing except by leveraging computers, smartphones, and other digital devices rather than traditional media, such as print, radio, or television.
4/25/2024 7:57:08 AM • Computers &... • Answered 20 hours ago
Where can i get mastering machine learning Tips for Tackling Assignment
Here
The Ultimate Guide to Conquering Machine Learning ...
makexyz.com https://www.makexyz.com > the-ultimate-guide-to-conqu... Feb 19, 2024 - When diving into machine learning assignments, it's essential to adopt a systematic approach. Break down the task into manageable components, ...
7 Steps to Mastering Machine Learning with Python in 2022
KDnuggets https://www.kdnuggets.com > 2022/02 > 7-steps-masteri... Sep 30, 2022 - Step 1: Learn Programming for Machine Learning ... You need to have a working knowledge of programming before you dive into machine learning. Most ...
Machine Learning Assignment Help
Medium · Abnerassignmenthelp 1 month ago Our experts can assist you in tackling machine learning assignments effectively. Deep Learning Assignment Help: Our team of deep learning . ..
4/24/2024 8:11:03 PM • Computers &... • Answered Yesterday
3answers
How do I find The best Roofing Service Contractor in Houston, Texas?
To find the best roofing service contractor in Houston, Texas, ask for recommendations from locals, check online reviews, verify licenses and insurance, and interview multiple contractors. Trust your instincts and choose wisely.
4/24/2024 4:31:29 AM • Computers &... • Answered Yesterday
Upgrades software
If you want to upgrade your software for example your operating system. Your systems unit support only for windows 7, windows 8 and windows 8.1. You may visit this website to download the latest driver for your operating system installed. http://support.lenovo.com/en_PH/downloads/detail.page?DocID=DS035527
4/22/2024 1:20:20 PM • Computers &... • Answered 3 days ago
2answers
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
4/21/2024 5:41:42 AM • Computers &... • Answered on Apr 21, 2024
2answers
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
4/21/2024 4:20:47 AM • Computers &... • Answered on Apr 21, 2024
Do you guys know some good custom web app development services?
DICEUS with 13 years experience. SIMFORM for modernizing legacy architecture. ColorWhistle for leads. PixelCrayons for tailoring to your specific needs.
4/18/2024 5:17:23 AM • Computers &... • Answered on Apr 18, 2024
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired anemployment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut. They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
4/17/2024 5:31:31 PM • Computers &... • Answered on Apr 17, 2024
How to get free backlinks?
YouTube Backlink Generator https://ovdss.com/apps/youtube-backlink-generator
4/13/2024 3:06:42 PM • Computers &... • Answered on Apr 13, 2024
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
4/13/2024 2:31:14 PM • Computers &... • Answered on Apr 13, 2024
3answers
How i free download tally
u need tally 4.5 free software (full ) if u need mail me i will give u link k
4/13/2024 2:20:33 PM • Computers &... • Answered on Apr 13, 2024
We have a Dukane Model No ACC5 Administrative Control Console and it keeps chirping. Not sure why or how to make it stop. Please advise?
This fault / alarm / warning is not listed anywhere and the company is no longer in business. Turn over the console and see if there is a door for a back up battery. It may be warning that it is running out. Do the same with the main control unit. You could also try powering off the main unit for 10 minutes to reset the software. https://www.google.com/search?q=dukane+model+no+acc5+administrative+control+console+chirping This is the unit that drives your admin console http://serialsistemas.com.br/duk/2/85101-0025%20--%20MCS350.pdf ..
4/12/2024 2:30:20 AM • Computers &... • Answered on Apr 12, 2024
2answers
To check if my sasseta certificate is registered
http://www.sasseta.org.za/ SASSETA Branch Contact Details Telephone Numbers: Call Centre: 27 (0)11 087 5555 Fax Number: 27 (0)11 205 0046 Switchboard: Midrand E-Mail: [email protected] Address & Map: Midrand Office Physical Address: Riverview Office Park Janadel Avenue (off Bekker road) Halfway Gardens Midrand 1685 Postal Address: P.O. Box 7612 Halfway House 1685 http://www.sasseta.org.za/content/tinymce/plugins/openfile/uploads/FRM_SKA_004_Application%20for%20Certificate%20Re-Issue.pdf
4/12/2024 12:53:51 AM • Computers &... • Answered on Apr 12, 2024
Would you want my fix for empowering technology pop up?
Removing/uninstalling empowering technology popup
BleepingComputer https://www.bleepingcomputer.com > forums > removin... Jul 30, 2020 - This annoying pop up started yesterday, it cannot be stopped. It blinks like a turning signal now. I looked everywhere for a fix or info on ... ..
4/11/2024 9:10:48 PM • Computers &... • Answered on Apr 11, 2024
Unknown ASUS N56VJ-WH71 15.6" Premium Audio Laptop with 3rd Gen Intel Core i7- Logo
1 questions posted
Top Unknown Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Unknown Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Unknown Computers & Internet
Most Popular Question
asus n56vj beeping
  • Computers & Internet
