20 Most Recent
Millennium Three M3 Discord 155.5 cm Snowboard with Flow Bindings Questions & Answers
Just bought M3 Discord bindings
First off if you have a 4 bolt pattern board it will look like this * * * * what you want to do is set the
* * * * Bindings on the board about shoulder length apart and thenfind the corresponding holes in underneath the slots in the bindings base. once you find the holes look at the edges of the round inserts, they have degree markings on them. i angle my binding about 15 degrees forward for the front one and 15 degrees back for the back one. This is a very freestyle oriented setup. for learning i would go 30 dergrees forward on the front and 15 degrees back on the back. and there you go your set to ride.Make sure you tighten all the screws very tight you dont want them coming loose on the mountain.also do not use locktight on the screws it can damage your board.
I am wanting to know
Do you mean how to ride it? Well first off your going to want to put your bindings on about shoulder width apart with your left foot angl;ed about 12-30 forwardand you back foot about 12-20 angled back. Then your going to strap in and start going down the bunny hill. bend your knees slightly and stick your **** out. I find its better to ride with a little more of my wieght shifted to the back. to start turns lean a little to the direction you want to go and the push or pull you back foot out depending on which way your turning( the pushin pulling is more for very sharp turns). to stop turn the board sideways and lean on the uphill edge, MAKE SURE YOU LEAN ON The uphill edge and keep the other edge from touching the snow otherwise you WILL fall and can hit your head easily.
Wearfit 2.0. Why can't I bind to my iPhone?
Discord users facing issues like
How To Fix Discord Not Opening so just make a call on Discord Customer Support 1-802-618-6092 anytime and experts are there on Discord Live Chat to help you 24*7 . Need any kind of guidance to fix the Discord issue so just make a call on Discord customer Service 1-802-618-6092 anytime and fix issues, a helpdesk is there to help you 24*7
