20 Most Recent
Cutler Hammer 125 Amp Main Lug Indoor Load Center Questions & Answers
We have a Cutler-hammer CH2100 main breaker that
I was able to go online and locate numerous sites that offered the ability to order the CH2100 and also the CH2100x main breakers. You could also take the breaker to an electrical supply and see what they have to offer as a replacement, but be sure that the connectors in the panel are not damaged before purchasing and installing a new breaker.
Can I replace a CEB CU/AL QB breaker with a QBH CU one?
nope breaker has to be rated for the aluminum wiring. if your home is wired with al wiring u need to be really worried bout that. it becomes a fire hazard awhile. should only use al for larger size wires and personally I wouldn't do that either
How to take apart cutler-hammer series B1 contactor
contactor itself replace it, to remove it from housing you should be to find some screws holding and just remove and replace. if you have the replacement already mark where the wires come from that u take lose
Gfi breaker keep triping
Might be their job or it's gone.
1. replace the breaker (cheap and fast) ... they do go bad.
2. Remove everything from the circuit and try each to find the short.
I just removed a cutler
Check where the main power wires come in to see if is has been properly sealed. Moisture may have found its way in through the opening and caused the problem. Hope this helps.
Bob
Hot bus bar YES! The Neutral bus bar gets HOT on
1991holiday ramble aumi lite when we pluged it in one of the wire was not wired right fix the wireing all works excepts the lights it blow all the bubs tryed new one the nights still will not work
