Electrical Supplies Logo
Posted on Aug 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a toy hauler with a 5500 guardian gen. It runs but recently it won't supply any 110 power to any of the electrical items in the camper.
Anonymous
Level 2:
New Friend:
  • Expert 122 Answers
  • Posted on Aug 03, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
122
Questions
0
Helped
33592
Points
296
There could be a couple of things wroung the breaker tripped have to reset the breaker the plug in went bad a wire came off or broke or the doid blew out you will need a meter to get in and check these out to see if any of these are bad most of the time it is a bad breaker that could be esily fixed or wire to the plug in either way they are pretty easy to fix.good luck
Need 101 help with my WFCO converter//charger Please! I installed a new refrigerator in the toy hauler. Have WFCO 68100 100 amp converter charger with 2-12 volt batteries. The converter seems to...
12 volts to 6 wow not a good thing to do my friend, check your converters power out put bye connecting a load to it,IE headlight or other load if it no light it no workey check for power to the unit AC check for fuses open if not replace the converter, all is OK if you did not get smoke when you connected a fresh set of battery's to your unit toy hauler distribution system.
best regards Falco
Guardian rv generator troubleshooting
You need to manually start it, and see if you have power right at the generator, if you do then it is somewhere in the coach. If you don't check the gen breaker, and have the gen checked
I have 110 at all my outlet's and the a/c work's but I have no 12 volt (lights in camper don't work) where's a good place to start on this
Your lights are 12volt.
Either, the lights work off camper 12V dc battery...
Or they work off 120Vac transformer with 12Vzc output.
If lights work when camper is not plugged into 120Volt, and there is not separate fuse or circuit breaker for the lights, then I guess the light work off the battery.
There is probably a cartridge fuse located under steering column
Many items on dashboard are fuse-protected with plug-in fuse available at auto parts.
Call local auto shop and ask where the fuses are located, or call local RV shop.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
Generator starts with and runs great, but theres no current on my toy hauler
Johnny,
If generators are not used regularly, they need the their magnetic field to be charged (or flashed). This can be done by plugging an electric motor into the socket while the generator is running and spin the motor by hand. The hand-spun motor will push some electric current back into the generator and magnetize it enough to start it.
Look in the manual. There is likely something about field flashing the magnetic field2.gif. The easiest way to do this is to.
1) start the generator
2) plug an electric drill into the generator (without drill bit)
3) make sure drill is set to forward direction (if a reversable drill.
4) pull the trigger on the drill.
5) If the drill does not start, spin the drill's chuck clockwise (When looking down at the chuck from the drill bit end). Spin counter-clockwise if holding it like a pistol and pointing away from yourself.
6) Do this several times (hard) until the the generator will kick in and suddenly make the drill spin at full speed.
Be careful not to drop the drill or poke someone with it as you celebrate success.
What is the oil filter for onan4000 generator
yes--- where is the oil filter on a onan 4000 in toy hauler?
1helpful
2answers
I hava a 20kw NG guardian gen. When it does its weekly 12 min. test run it most always runs rough and seems to be choaking itself to death.
I have a 400kw unit that does the same thing, I found the regulator needed to be execersized. when the unit starts I shut the isolation valve ahead of the regulator and then when it almost shuts of the gen. i open the valve back up and then everything is ok, hopefully after awhile it will work right.
5helpful
Oil type for Onan 4000 generator
SAE 15W-40 is what i used to use
synthetic? not sure about that one there may be oil pres switch that could give you a problem.
Top Generac Guardian Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Generac Guardian Electrical Supply Expert? Answer questions, earn points and help others
