How many HDMI Inputs are available on the TV?
Also, are you trying to project your computer to the TV or get TV on your PC?
I will assume the first scenario. The only thing I can suggest is that if there are multiple HDMI inputs then you will need to choose the correct one to change it to. If it does not give you that option on the TV input switcher menu then you can try to plug and unplug (while everything is on and attempting to project) the HDMI cable into different inputs on the TV until you find the right one.
Alternatively you can use a VGA/DVI cable depending what is on the back of the TV and that will definately work, but won't be HD.
Hope this helps.
