I have a 2000 Dodge Stratus. Running fine yesterday, get in it this morning and it will not strart. Radio, windows, everything else will come on, but nothing when I turn the key. Help.
Check the fuses . I had the same problem
Sometimes the connection on the battery is good enough to run small things like that but not put off the power to start an engine. You either need a new battery, check to see if it has corrosion on the terminals or check to see if a terminal is loose. That might not be it.. but it will defintely eliminate somethings.
