Yahoo Messenger Logo
Posted on Feb 27, 2011
How to sing up new yahoo messenger? - Yahoo Messenger
  • Anonymous Feb 03, 2012
    yahoooo is awsome
Anonymous
Level 1:
Novelist:
  • Contributor 347 Answers
  • Posted on Feb 27, 2011
Anonymous
Contributor
Level 1:
Novelist:
Answers
347
Questions
Helped
37373
Points
14
Go to this link and on the top right you will see sighn up and sighn in then click on sighn up it is in the very top right hand side i am in the uk but you will be auto linked anuyway
Everytime i try to sing in to yahoo messenger chatroom messenger stopped
There should be a Help page to answer your question. I don't think chatrooms work just by singing into them.
Can't sing in to my yahoo messnager
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
you may have a registry problem download reginout to fix the issue
Why i can not sing the yahoo i have right yahoo email and password
you may have a registry problem download registry cleaner reginout to fix the issue
How to sing in yahoo messenger
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences." 2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window. 3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button. 4. Enter your Yahoo! ID and password and click the "Sign In" button.
you may have a registry problem download registry cleaner reg in out to fix the issue
1helpful
My yahoo messenger sing out autometically and
Dear Sir,
plz folow this step,
make sure your firewall settings are disabled or changed to allow messenger...........then click on <messenger> before sign in then click on <connections and preferences> there you have to mark an option <use no proxy> and thats all........if dont work then remove that messenger through control panel and add/remove programs and download through the add below.
www.freecreed.com
Thanks For Your Time,
1helpful
I cant sign in plss help me if i sing in there
The best attempt to unlock your ID is, try to login not by yahoo messenger, but by mail of yahoo which has a same user name and password that been locked. Sometime, this step worked, but make sure after your login to yahoo mail and success, you have to change your password with new password, and then you can login to yahoo messenger with new password that you just been created.
If you try to send a complain to the contact of yahoo messenger, It will useless. Yahoo doesn’t care what happen to your if you go locked.
To protect your ID or to prevent Lock ID, you must have a strong password. I will suggest you to not chat with your primary email in yahoo messenger. Sometime yahoo makes a prohibition to some of ID. This mean your ID can be banned by yahoo and your ID never be join to yahoo messenger or yahoo email again.
To create a strong password you must use all character who listed in your keyboard. Such as uppercase, number, and symbol. You must be create password which have not less 8 character or more.
Here I give you an example a strong password: H4rP3 ^&* (with 3 space on it). To make a better password work well, you have to change your password frequently: 3 week or 3 month, depending how strong and important your password i
3answers
I cant open yahoo messenger.it say 'there was a problem singing into yahoo messenger.please try again a little bit later'
This is because your internet connection is not constant..
Check your internet connections...
If that doesnt solve...Select..PROXY in yahoo messenger settings..
This should help you..
1helpful
2answers
Yahoo messenger sing in problum
Offhand, a couple of possibilities you can try to explore, check or perform:
  • clean your cache and temporary internet files;
  • re-install Yahoo Messenger;
  • verify your account by checking your Yahoo email.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
2helpful
2answers
Yahoo messenger sing in problum in 9.0 version
I'm unable to access my ym, plz halp me..........
Top Yahoo Apps Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Yarik Bess
Yarik Bess
Are you a Yahoo App Expert? Answer questions, earn points and help others
