1) Insert your card in the mmc reader. 2) Find the drive in which it is inserted from your pc. 3) Right click the selected drive and select FORMAT but NOT quick format. 4) Now, in the file system selection part, select the file system to be FAT and not FAT 32 or NTFS file system. 5) Start formatting.
You can backup all your important data to your PC, & then format both phone & memory card. Or try to delete application files, using xplore delete files all at once from folders "system\programs" and "system\recogs then........
First format your mmc with pc computer using card reader.And then format/reset your cell.Don't insert mmc to cellphone until you formated both memory.For nokia s60 try insert code *#7370# to format it.
You can also delete it manually with lcg xplore
1. Kill the processes qwpuec.exe
2. With lcg xplore find and mark the virus at
c:/system/apps/qwpuec.exe and qwpuec.sis
c:/system/data/qwpuec.exe
c:/recogs/qwpu.mdl
e:/system/apps/qwpuec.exe
e:/system/recogs/qwpu.mdl
3. Delete (if it can't be deleted,change its attribute 1st
you just have to remove ur mmc from ur phone and tn cnnct it to computer via card reader go to my computer >external devices > righth click on it >and u will find a option of formatting just format it and then put code 1234
You can remove the mmc but keep the sim card and restart your phone.
Then press the keys *#7370#.
The phone would ask a confirmation.
Select yes.
Then it will ask for a code.
Type the phone lock code (the default code is 12345).
There you are! your phone will restart with all the phone memory formatted.
Tips
Also remember that you can reset your phone but not loose any of
your personal files (I.E restore the settings that came when you bought
the phone while keeping contacts etc) by following the above procedure
but using the code *#7780#
Warnings
Don't apply these steps if you are not sure what you are doing.
Make sure you have enough battery power before beginning this procedure.
Formatting will erase all your contacts/messages, so make a backup of your phone before formatting.
Please try to format the memory card using a memory card reader on computer and then insert the card back in phone, it will say corrupted again, but now you try again to format it from phone and it should work now,,.....
put ur locked memory card in N70 and format it... hope it will work... or go to some mobile repairing shop there you'll find a tool called MMC-unlocker... they will unlock it if you want your data back...
If you encounter situation like below on your 7610,
1. Blank screen phone unable to reboot. 2. Phone only able to boot-up to "Nokia" word screen. 3. Install some program but not able to uninstall it after that. 4. Error messages such as "Child Installer" keeps popping-up.
Do a Full phone formatting on your 7610! as steps below,
1. Make sure you have at least 3/4 charge of battery power left. 2. Backup your contacts list and personal files to MMC memory card. 3. Switch-off your 7610 phone. 4. Press and hold 3 keys; Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 7610 phone.
Remember, do not let go all of the keys and hold keys until you see a formatting word screen show!
5. After a few minutes when the Full phone formatting completed, your 7610 will back to original system and factory settting.
All apps installed & not of the phones' default will be lost. If you did a backup on your mmc, you can restore it back to the C drive again.
Thank you for rating this Tip
