Battery Replacement
You have to dismantle your watch first.
Check the back of case- if there are visible screws- undo them and take caseback off. You should see the battery. Take it out, read the numbers on battery and replace with the same one.
If you can not find any screws on caseback- you have to undo screws from the dial side, get the movement out and then change the battery.
BE WARNED: if the watch must be opened from dial side, you can easily damage it as some particular skill is needed. Do it on your own risk.
Good luck
