Pulsar 100 Meter Alarm Chronograph PF3277 Logo
Posted on Nov 05, 2010
I have a pulsar watch Y960-6018(A5)what is the replacement battery please
Battery for Pulsar man's watch 780266?
that looks like a serial number. The 266th watch made in 1978.
Pulsar seem to use a few different batteries.
https://www.google.com/search?q=Battery+for+Pulsar+men%27s+watch+780266
This is the best advice
https://www.fixya.com/support/r27181038-changing_watch_batteries
Pulsar watch model# 660137, what size batteries
Best advice
That model number doesn't follow Pulsar's model numbering scheme and is likely a serial number.
The stock answer is the same battery as the one that is in it.
https://www.google.com/search?q=Pulsar+watch+660137%2C+replacement+batteries
1helpful
2answers
Pulsar analog/digital watch model number 130139
Clearly, it is faulty and has some type of parasitic drain. All watch batteries should last a couple of years. My Seiko last for about 3 to 4 years. Return it to Pulsar or a repair agent for repair.
Pulsar Watches - Tell it your way
https://www.pulsarwatches.com.au
Service & Repairs Service Agents Watch Care FAQs Instruction Manuals · Contact. PULSAR. Pulsar. ©2021 Seiko Australia. All Rights Reserved.
‎Watch Care · ‎Customer Service · ‎Abbreviations · ‎Glossary
Pulsar Watches - Contact
https://www.pulsarwatches-europe.com Pulsar burst onto the world watch scene with the first ever LED watch. Ever since, the name has been synonymous with adventurous and leading edge design.
1helpful
VX82 X530 Battery for Pulsar watch
The VX82 X530 battery is a replacement battery for the Pulsar watch. It is a lithium-ion battery with a capacity of 3.7V and 530mAh. It is important to note that you should only use a battery that is specifically designed for your Pulsar watch, as using the wrong type of battery can damage the watch or be potentially dangerous. Always use caution when changing a watch battery.
Yyou can try searching for "VX82 X530 replacement battery" or "Pulsar watch battery replacement" on online retailers such as Amazon, eBay, or Alibaba. You may also check with the manufacturer of your Pulsar watch or a local watch repair shop for replacement options.
5helpful
Battery problem
Stop panicking, please. If you lost the battery, that means your watch has been opened, so, read the movement number and submit here. Then Ill be able to give exact battery number.
5helpful
2answers
Pulsar NX14 Digital Display gone blank
Do not panic yet - all you need is the battery replacement.
Don't mind that the watch is less than a year old - it may laid in sellers store for a year or so and as the watches are not refitted with the brand new battery at the selling point, they may have underpwered battery much more quicker than you expected
Find your nearest watch repair shop and ask for battery replacement. Your watch will tick as brand new and will last much longer then before.
Do not forget to rate, please.
Jan 12, 2009 • Watches
1helpful
2answers
Need to replace battery
Take the watch to a jewlers, let him replace the battery they usually only charge for the new battery,
and they do not cost much.
Top Pulsar Watches Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Pulsar Watch Expert? Answer questions, earn points and help others
