SOURCE: Unable to download pictures from computer to digital frame
The primary software is going to extract all the images, put only the images you want on the card, then insert into your picture photo frame.
SOURCE: How to copy music files to my Smartparts
Are using a memory card. If yes, than go to "my computer" than click on drive that has memory card. (probably i: drive)
The Music file is probably is mp3. Pictures are DOC
SOURCE: can not find the setup file for the smartparts 7 inch digital pic
The setup file is on the frame. Connect the frame to your computer w/ the USB cable. Go to MY COMPUTER. Look for your frame as a removable device and open it up. There is a blue icon called "setup." If you click on it, it will start to download to your computer. If you can't find it, you can download from Smartparts website at this link:
http://smartpartsproducts.com/content/support/optipix/optipixlogin.php
SOURCE: SmartParts Frame SPX7E only allows me to load 165 photos
2 answers...
To remove a picture, connect the frame to your PC via USB. you should see the frame appear as a drive, in my case,
36972 (E:)
open the drive as Explore, you can now see the pictures, and delete what you no longer want.
you can download the software from
http://www.smartpartsproducts.com/content/support/optipix/index.php
SOURCE: Hello. We received a SmartParts digital picture
Probably more than it's worth! Many of these items were found to be defective when shipped. This is the 41st one of these I have heard about with the same problem.
If you can return it for a refund or swap for another brand.
Please rate my help++++Thanks for using FIXYSA
