Cars & Trucks Logo
A
Anonymous Posted on Sep 10, 2017
I have a 2002 Chevy Avalanche 2500 with dash lights out. Not only did these lights go out but the power locks also stopped working at about the same time. Not sure if that is coincidence or what. All the gauges work fine but don't light. Same with the lights for the fan and temp adjustments. All lights went out at the same time. Could you tell me where to start. thanks
Jeff Armer
Level 3:
  • Cars & Trucks Master 15,575 Answers
  • Posted on Sep 10, 2017
Jeff Armer
Level 3:
Answers
15575
Questions
Helped
7112185
Points
73899
Factory repair manual step by step testing procedure for Interior Backlighting Inoperative. In your course of testing let me know if you need location for anything .
Turn ON the parklamps.
Ensure the panel dimmer switch is at maximum illumination.
Do the illumination lamps operate normally?
YES - Go to Testing for Electrical Intermittents in Wiring Systems
NO - Go to Step 3
Is only one lamp inoperative?
YES - Go to Step 4
NO - Go to Step 6
Test the instrument panel lamp supply voltage circuit of the inoperative lamp for high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
YES - Go to Step 17
NO - Go to Step 5
5
Test the ground circuit of the inoperative lamp for high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 17
NO - Go to Step 11
6
Do the park lamps function properly?
YES - Go to Step 7
NO - Go to Park Lamps Inoperative
7
Inspect the ILLUM fuse.
Is the fuse open?
YES - Go to Step 12
NO - Go to Step 8
8
Connect a test lamp between the ILLUM fuse and ground.
Does the test lamp illuminate?
YES - Go to Step 14
NO - Go to Step 9
9
without disconnecting the switch, connect a test lamp between the instrument panel lamps dimmer switch signal circuit at the headlamp and panel dimmer switch and ground.
YES - Go to Step 13
NO - Go to Step 10
10
Inspect for poor connections at the harness connector of the headlamp and panel dimmer switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
YES - Go to Step 17
NO - Go to Step 16
11
Inspect for poor connections at the harness connector of the inoperative bulb. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
YES - Go to Step 17
NO - Go to Step 15
12
Repair the short to ground in the instrument panel lamp supply voltage circuit. Refer to Wiring Repairs in Wiring Systems.
Replace the fuse.
YES - Did you complete the repair?
NO - Go to Step 17
13
Repair the open in the instrument panel lamps dimmer switch signal circuit between the switch and the fuse. Refer to Wiring Repairs in Wiring Systems.
Go to Step 17
14
Repair the open in the instrument panel lamp supply voltage circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 17
15
Replace the inoperative bulb.
Did you complete the replacement?
Go to Step 17
16
Replace the headlamp and panel dimmer switch. Refer to Headlamp Switch Replacement .
Go to Step 17
17
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 3
5 Related Answers
Anonymous
  • 4669 Answers
  • Posted on Mar 08, 2009
SOURCE: 2002 Avalanche gas gauge problems
Gm has a real problem with fuel tank sending units. That is what is wrong. You need a fuel tank sending unit. You can only get them aftermarket with the whole fuel pump module, but you can buy them seperate if you buy it from the dealer.
Anonymous
  • 79 Answers
  • Posted on Mar 22, 2009
SOURCE: 2005 chevy equinox temp gauge showing hot fan
check the coolant temp sensor
Anonymous
  • 8 Answers
  • Posted on Jul 19, 2009
SOURCE: 05 2500 chevy no dash instro operation
Check for factory recall, some models affected.
Anonymous
  • 1986 Answers
  • Posted on Sep 09, 2009
SOURCE: 2003 CHEVY AVALANCHE dash board telling me left
check the lil switch that'll be located on the latch anchor point or within a few inches of it.... odd is the switch is faulty
Danniboi
Dan Doherty
  • 1099 Answers
  • Posted on Feb 01, 2010
SOURCE: THE OIL PRESSURE GAUGE DROPS TO ZERO AND LIGHTS ON
poor oil circulation may need either more oil or a new oil pump, any other symptoms?
It could just be the pressure sensor, as this is cheaper get it looked at first.
Hope this helps
Regards
Dan
2answers
How to reset the lite on dash board " change engine oil" on a automatic 2002 chevy avalanche Z66?
Different car has different way to reset. Read its manual, it should tell how to reset.
mai
2002 chevy avalanche died at a stop light and now wont start back up. it just cranks.
Those are known for having the fuel pump go out. Take the gas cap off, open the little steel door with a screwdriver and have someone turn the key forward, not cranking it over, just turn it until all the dash lights come on and see if you can hear the fuel pump kick on for about 2 seconds. You definitely need 2 people to do this. If you can hear the fuel pump then its probally not getting spark.
AC compressor not kicking on
The Trainer 40 When the compressor won compress
back lighting for a couple of the climate control dash board buttons are not working. ?????? wouldn't be a fuse , bulb probably . You would need to take the component apart to replace the bulb .
3helpful
2002 chevy avalanche wont go into 4 wheel drive the lights on the dash just blink
the motor on ur transfer case is locked up .... if u don't use 4x4 once in a wile it will happen to all GM trucks
1helpful
Chevy steering wheel controls
You first have to disarm and remove the air bag (unscrews with bolts from behind the steering wheel) and then you will see the screws for the switches. Only the silverado awitches will work.
Shift indicator light on dash
Check the connection of the small light on the back of your I.P.C. if this looks good you need a new I.P.C. (gauge cluster)
3helpful
3answers
Where is the abs control module located on a 02 chevy avalanche ?
THE EBCM IS BAD this is the electronic control module that is on abs pump. you can replace seperate I think it is around 500 for part
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
