Apple MacBook Air Logo
Posted on Apr 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I'v got a MacBook Air, and it won't turn on as it goes: on, the Apple logo shows, the waiting wheel spins and then turns off again, and keep doing this till i shut it down for good... it won't turn on... help me please =(
Ex2bot
Level 2:
Scholar:
  • Expert 65 Answers
  • Posted on May 02, 2010
Ex2bot
Expert
Level 2:
Scholar:
Answers
65
Questions
0
Helped
12677
Points
108
Try:
1. Turn your MacBook Air off by holding down the power button for about 10 seconds.
2. Hold down one of the Shift keys and press the power button for a few seconds. Keep holding the shift key for about 1/2 minute. This will start the machine in "Safe Mode." It will check to make sure there are no errors on your hard drive and do other tasks to hopefully fix your problem.
3. Once you see your Desktop (if you do), click the Apple menu and click "Shutdown".
4. Start the computer normally by holding down the power button for a couple seconds.
If this doesn't work, you may need to reinstall the operating system. On a MacBook Air, that's a bit more complicated. You'll need either the external DVD drive (an optional purchase for the Air) or another computer. Your computer manual explains how to install software on that other computer (may or may not be necessary) so that you can use that computer's DVD drive to put the disc in and reinstall Mac OS X operating system.
Good luck! Please let us know if you have further questions or problems.
* If you find this information helpful, please rate my solutions and recommend me. Thanks! *
Adam Jems
Level 1:
Habit-Forming:
New Friend:
  • Contributor 9 Answers
  • Posted on Oct 16, 2018
Adam Jems
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
9
Questions
0
Helped
1913
Points
42
To resolve this follow the given Below steps -First, Shut down the Mac >Then connect it to your MagSafe adapter >Hold down the Shift+Control+Option+Power button at the same time for a few seconds.> Now Release all keys at the same time, then boot the Mac as usual. if still, your MacBook Air Won't Turn On then visit - https://www.mactechnicalsupportnumbers.com/blog/fix-macbook-air-wont-turn-black-screen-problem/
1helpful
I have a Macbook Pro late 2011. 2.4ghz 4 gigs of ram 500gb hard drive. My computer wont fully start up. When it turns on it shows the apple logo the spinning wheel and loading bar. Then the bar goes away...
Yes, there is a way to backup your Macbook .. but it will require you removing the hard-drive and using a SATA to USB adapter so you can retrieve the data from it.
Video on how to remove HDD:
http://www.youtube.com/watch?v=j1f7wotR_CQ
SATA to USB:
http://www.amazon.com/Vantec-CB-ISATAU2-Supports-2-5-Inch-5-25-Inch/dp/B000J01I1G/ref=sr_1_1?ie=UTF8&qid=1352310179&sr=8-1&keywords=sata+to+usb
Apple macbook air won't turn on
Does the Apple logo or the Pinwheel show on the screen?
There is a problem with you OSX installation. Please boot from the Recovery partition (hold Cmd+R during the startup chime), and use Startup Disk to choose the correct hard drive to boot from.
You can also restore from a backup, and not lose your data here as well.
2answers
I have a macbook air, and i turned it on today and the white screen appeared on the screen with the apple logo, then the wheel started spinning for hours and it doesnt turn on, i wonder how can i fix it?...
Find you apple install CD's and choose the one that says application install. as you turn in on try and put the CD in and hold down the D key this should run the disk before start up and allow you to run a hardware check.
My apple macbook air will not reboot. it turns on but does not reboot completely then it shuts down and tries to reboot again and again. apple logo appears and the spinning icon rotates but never goes...
It may be a possibility that the hard drive has gone bad or a connection to the hard drive. The spinning wheel and apple signify the kernel boot, or in other words, the process in which the machine finds the hd and os/software.. you need to bring your machine into an authorized repair center to have a system diagnosis to verify that no other parts of the machine are bad. That model is notorious for having bad hd's.
Your best bet is to reset the System Management Controller;
http://support.apple.com/kb/ht3964
...and then reset the Parameter RAM:
http://support.apple.com/kb/ht1379
If it persists after that, try Safe Mode:
http://support.apple.com/kb/ht1455
...if that persists, try booting to your install DVD and running Disk Utility:
http://support.apple.com/kb/ts1417
..also note in this article that if for some reason you are unable to boot into your Install DVD the instructions for using fsck will do the same thing.
If that fails to resolve the issue, you'll want to reinstall the system, but that is a bit more of a sticky wicket since you're on a Macbook Air that does not have an optical drive. You can use remote disc sharing with another Mac to do this:
http://support.apple.com/kb/ht1131
...and then boot to that shared disc:
http://support.apple.com/kb/HT2129
..and then reinstall:
http://support.apple.com/kb/ht1710.
If none of these steps resolve the issue, it will likely need repair at an Apple Authorized Service Provider or Apple Store.
3helpful
My MacBook turns on, but stays on a white screen and does not load the OS. Any ideas how to fix?
Dose the apple logo comes and the spin or no ?
if its coming permission issues
if dosent come the apple logo and the spin then please reset the eprom
by pressing command +option+p+r and press the power button to on and wait till you listen three times the chime the third time release all the button and say hello to your Personel desktop
thanks
3helpful
Help with my macbook air, it shows only the apple logo and a spinning wheel
Power the machine down. Press the power button to turn it on. After you hear the startup chime, press and hold the shift key. This will trigger an extended file system check and a safe boot. Continue holding the shift key down until you see the spinner, then you can release it. If it doesn't boot completely after this, you will have to bring it in to an Apple-certified tech for repair.
3answers
Mac book air cannot start
When troubleshooting a Macbook Air, there is a checklist from Apple Support you need to try.
You are welcome to do so after first trying these steps first.
• Check the Magsafe power adapter, to make sure it is free of debris and is seated properly.
• If with decent charge, try to start the Macbook Air, with only the battery.
If you get power from either one of these issue resolved- otherwise follow the steps provide more in detail from Apple listed in the link below.
Apple Support Link:
Troubleshooting Macbook Air (additional steps)
Such power issues with Macbook Airs as well as Macbook 13" and Macbook Pro 13" are about the same and there are no workarounds, so make sure to follow those procedures completely for a full assessment of your Macbook Air's functionality.
Hope this helps!
Regards,
-Mactechtrainer
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
