I have had this problem now three times. Twice the dealership has replaced the entire left door speaker. It's out again and this the car is no longer under warranty.... is there an easier fix/less expensive fix now?
You need to replace the left front door speaker
Replacing the radio is the only thing that fixed my speaker issue with mine, Dealership I work at replaced ALL speakers and it turned out to be a radio issue,
SOURCE: Have a 2007 Pontiac G5 and need to add power steering fluid.
its tricky. its behind the engine. If you pop the hood and you go to the left side, look behind the block and it chould be about half way down or so. You should see the cap for it. I think that was a horrible idea on pontiacs part. Happy motoring!
SOURCE: How do I change the Belt on my 2007 Pontiac G5 GT
Do a quick sketch of the pulleys and the path of the v-belt around them. The tensioner pulley is the smooth faced one that the smooth back of the v-belt runs around. In the middle of the pulley is what looks like a nut. It is in fact a fixed spindle. If you fit on a correct socket you can push the tensioner pulley against its spring by pulling down firmly in an clockwise direction. This removes tension from the v-belt which should then be slipped off with little effort . Fit the new v-belt over the driven pulleys in the same orientation as the old one (your sketch should be your reference) remove tension on the tensioner pulley as before to get the belt over the last pulley which should be the small diameter alternator pulley,
SOURCE: The power steering light is on in my 2007 Pontiac G5 Coupe
