Cars & Trucks Logo
Posted on Mar 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
P1493 code Hi,I own a 2002 Dodge Ram 2500 4x4 sport.Check engine light is coming on.p1493 code came on about 3 months ago.checked connection at battery tray 3 months ago,cleaned,put a little of dielectric grease for good contact,cleared code.Engine light stayed off till a week ago,checked,p1493 code retrieved, replaced battery temp sensor,cleared code. After driving truck about 5 mi...,-code still coming on..? What else should I try?
Anonymous
Level 3:
  • Master 783 Answers
  • Posted on Mar 11, 2010
Anonymous
Master
Level 3:
Answers
783
Questions
Helped
219964
Points
2220
If you are running any extra systems, ie amps, subs, high watt speakers, etc. etc. you may need to get a better batter, like the blue. or yellow top one. check with auto zone.
Arnie Burke
Level 3:
  • Dodge Master 7,339 Answers
Arnie Burke
Dodge Master
Level 3:
Answers
7339
Questions
0
Helped
1824019
Points
21459
Get truck scanned for any bad code-computers r complex and things dont all show--if that doesnt help u may need to hook up a data recorder while driving-these r usually at shops
2answers
Check engine light 2007 ram 1500 hemi. I've owned
There is no standard interval for the CE/MIL light. You need to get the codes scanned at a local AP store to see what codes you have.
P1684 p0302 p1493
P1684 - Less than 50 Key On's.
P0302 - Misfire at Cylinder #2
P1493 - Ambient/Battery Temperature Sensor Input voltage too low.
Oil Light with the correct oil level = Oil Pressure/Sending Sensor.
2answers
I have 2002 Dodge Caravan Sport, check engine light came
If it where me I would start considering the only common part between all these effected systems. The ECM although the dealer should be able to say for sure. They have a machine that actually replaces the ECM and can simulate all the sensors. I had to say it but you may need to take it to a dealer for complete diagnostics and repair since the machine is a dealer only type machine.
2002 Dodge Ram Gas Engine. Check Engine light
check your antifreez . that would make check engine light come on and no heat
Engine stalls in drive after check engine light came on.
Have it sacnned for a code. it seems to be the speed sensor at the tranny.or the crankshaft position sensor. hope this helps. will you please vote ?
Engine stalls on a 2002 dodge ram 1500 when put in drive. check engine light came on when I was on a trip
Have it scanned for a code. it could be a variety of things that are wrong. And I am almost sure it is a sensor. Specially the cranshaft position sensor or the Idle position sensor.
2helpful
2answers
I have a 96 eclipse and the check engine and battery light are on, the code it throws is p1493 and p0117 what is wrong with it?
P1493 Battery Temp. Sensor, Low Voltage
P0117 ECT Sensor, Low voltage
Make sure the engine is reaching operating temperature, U may have a problem w/the thermostat, this is code P0117
Have the battery and the Alternator tested for possiable charging system issue, this is code P1493
1helpful
Check engine code p1493. the check engine light and battery light is on what does this mean?
P1493 Battery Temp. Sensor, Low Voltage,Solution: have the Battery and the Alternator tested, Auto Zone and Kragen as well as others do this for free. I suspect your Alternator is the problem.
1helpful
2answers
Dodge Ram B250 1994 - has a Starting Problem
if you van has a security system in it, it could be causing this problem. they usually disable the starter circuit. Paul has listed good places to start. but if they don't fix it do this: when your trying to start but its not working have some one check voltage at the starter. there are 3 points to check 1: where battery cable connects 2: where starter connects to solenoid 3: small wire that operates solenoid. if there is voltage at all three point replace starter it has a shorted / open spot on armature. voltage at 1 and 3 but not 2 replace solenoid. voltage at 1 but not at 3 and you have already checked the items Paul identified check wiring between neutral safety switch and solenoid.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
