Macromedia Flash MX Logo
Posted on Feb 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't ope a protected movie error while opening
Can't open a protected movie error while opening the .swf file using flash player
Anonymous
Level 2:
  • Expert 242 Answers
  • Posted on Feb 24, 2010
Anonymous
Expert
Level 2:
Answers
242
Questions
0
Helped
61740
Points
726
You may need to reinstall the Flash Player. The copy that you have might have been corrupted.
Try the below task and i am cent% sure it would work.
Do you have jv16 Power Tools installed? There's a link below if you
don't. With that program you can go into Registry Tools > Registry
File Types and disassociate .swf files with Windows by removing it.
http://www.oldversion.com/program.php?n=jv16
You should uninstall Flash Player, they have a utility for that
here:
http://www.macromedia.com/support/fl.../playerfaq.htm
Reinstall the latest version of Flash Player and hopefully it will
automatically reassociate itself with .swf files.
Enjoy the game where name is game... ;)
1helpful
2answers
Which software could run a swf file?
Hi Joanne,
.SWF are flash files and require Flash player. Check if your PC has flash player installed.
Go through the link and check the details. Play SWF Files How to Open SWF Files
Regards,
Sean
tip
FLV to SWF converter for mac, convert Flash FLV to SWF on mac
PartI. Difference between FLV and SWF
PartII. How to play FLV and SWF on mac
PartIII. How to convert FLV to SWF on mac
PartI. FLV VS. SWF
What is FLV?
FLV files (Flash Video Files), a binary file format, are composed of a video bit stream and an audio bit stream and deliver web video over the Internet with Macromedia Flash Player. FLV files are considered to be streaming video files. If you put FLV file in website, you don't have to download the entire file before playing. FLV content may also be embedded within SWF files. The audio and video data within FLV files are encoded in the same way as they are within SWF files. Unlike SWF format, FLV do not have maximum of 16000 frames limitation and ideally for large video file size. Notable users of the FLV format files are YouTube, Yahoo video, Google Video, Reuters.com, My Space, Facebook video etc.
What is SWF?
SWF (Shockwave Flash)- The file format SWF is a vector graphics file format, not streaming media. SWF file can be played directly in web browser, such as Internet Explorer. However, FLV file can not be playback directly, because it requires a separate SWF file which reads the video content from FLV. The SWF file that plays FLV file is called online flash player. Intended to be small enough for publication on the web, SWF files can contain animations or applets of varying degrees of interactivity and function.
PartII. How to play FLV and SWF on your mac
FLV and SWF are currently very popular over the Internet. When you have downloaded many cartoon movie files which are in SWF file format from Internet or downloaded a video from video sharing website like Youtube to your Mac, you must want to play them in the formats of FLV and SWF. However the default Player on Mac, QuickTime Player, can't playback them. Luckily, the problem will be fixed when you use SWF&FLV Player.
SWF&FLV Player, which is based on the standard Adobe Flash player for Mac OS X, SWF & FLV Player by Eltima Software offers advanced and unique features that allow you to play, rewind, fast-forward and preview SWF and FLV files frame-by-frame, and also create and manage playlists, zoom movies in and out, fit to current window size or restore to original one, set playback quality, control Flash security, check SWF file’s comprehensive information and lots more.
Want to publish your website and insert a SWF file into it, right? Use Flash 8.0 to create an embedded SWF with for your web site, however, you will find that the created SWF file goes out of sync in video and audio. How to solve this problem?
A workaround is FLV to SWF converter for mac which is a special flash creator. Mac FLV to SWF converter can convert FLV to SWF as simple as a piece of cake, without any actionscript and programming. Mac FLV to SWF converter empowers you to embed your SWF in a HTML web page during flv to swf conversion.
Step1. Add FLV files
Click "Add video" button to open the directory and choose all FLV files you want to convert.
Step2. Take slide
Choose two or more FLV files and click "Slide" button.
Step3. Choose a customize flash player
Go to "the step3 of cutomize" panel, and then hit "Player" tab to choose a customize flash player for your flash video.
Step4. Set a flash preloader template
Press the "Preloader" tab to select a cool flash preloader template.
Step5. Convert FLV to SWF
Hit the "Start" button to start FLV to SWF conversion.
Next: Create free flash slideshow for website with photos.
on Jun 24, 2010 • Computers & Internet
tip
IMovie export Flash FLV/SWF, iMovie export for web with iMovie to Flash...
iMovie is an excellent and easy-to-use editing program that is produced by the Apple Inc. Once you have finished your editing, there are a few movie formats to export.
Export iMovie to Quicktime
1.To save the imovie video as quicktime file, Go to the "Share" menu and select "Export Movie..." option to open the "Share" window, then choose "QuickTime" icon.
2. In the "Compress movie for" pop-up window, select an option and press "Share"
3. To choose the type of export format, click "Options" button to set the compression, frame rate and key frame. Then click "Save" and the imovie video will be saved on your mac.
Export iMovie to DV Tape
You can save your movie finished with iMovie as a raw digital video format on DV tape
1. Get a blank DV tape in your camcorder and connect your camera to your computer with a FireWire cable, then set your camera to VTR mode.
2. Go to "Share" menu and choose "Export Movie..." option to open the "Share" window, then choose "Videocamera" icon. Finally click "Share" button and wait for a moment, your movie will be saved on your DV tape.
Export iMovie to iDVD
You can export iMovie as a file which can be workable with iDVD for burning a home DVD.
1.To export a file to iDVD from iMovie, Go to "Share" menu and choose "iDVD" option.
2. Press "Share" button and choose a destination for it and click "Save".
Export iMoive to Flash FLV/SWF for web
You won't find any export option in iMovie for exporting iMovie file to Flash(FLV/SWF). So how should you do to export imovie to Flash for your website? One tool is required, that is Doremisoft Video to Flash converter mac. Therefore, when you have done your movies in iMovie and would like to add the movie to your website, you can achieve it by the ways of exporting iMovie movies to hard disc as a Quicktime clips and then converting Quicktime movie to Flash FLV/SWF with the mac video to flash converter.
How it works:
1. Export iMovie movie to Quicktime(See the above details)
2. Download, mount and launch the video to flash mac converter. Then click the "Add Video" button and go to the video folder where video clips exported from iMovie is stored, choose them. Finally, hit "Open".
3. To set the output format, open the "Step2 of Customize" window and you are allowed to check "Generate FLV or Generate SWF or Generate HTML" to set FLV or SWF or html page embedded with flash video as your output formats.
Tips: You must choose either Generate FLV or Generate SWF or both. If you haven't check Generate SWF, you can't choose Generate HTML and if you haven't choose Generate FLV, you can't choose Generate SWF-->Play the created external FLV file progressively. If you choose Generate SWF-->Play the created external FLV file progressively, Generate thumbnail is selected automatically.
4. To select a flash preloader template, click "Next" button, hit the "Preloader" button and add a flash preloader to your flash video.
Tip: This step is valid only when Generate SWF-->Embed the video in SWF and play in timeline is select at the last step.
5.When all settings has been done, it is time to start iMovie to Flash FLV/SWF conversion. After conversion, you can upload the flash video to video sharing website or post them into your webpage.
Next: Convert DVD to Flash & embed DVD in website and blog.
on Jun 22, 2010 • Computers & Internet
1helpful
3answers
Iwisoft swf to video failed to open file please help
I doesn't use the tool, instead I'm using the Kvisoft swf to video converter. I've used it several times already and it works in Flash to video conversion.
As i try to download Adobe Flash player it says i already have the newest version , even though i can't find it anywhere on my computer , so now i can't open any swf-files
@darknessf4
In order for you to view SWF (ShockWave Files), you need to install Adobe ShockWave Flash Player. You can get it here. You could also use SWF Opener that you can get here. If you're trying play a video on YouTube but you're getting the error "You need to install the flash player", check this troubleshooting guide.
Good luck
4answers
How can i open a swf fil?
swf is a flash file download and install adobe flash.
2helpful
Cannot open a protected movie
You'll need the original .fla file. Or decompile it using something like this.
2answers
My computer will not open swf files. how do i correct that. D
check your related software for swf files, whether it is working properly or not?
usually, it is a macromedia flash player files. so, try to update or install the flash player software in your computer. then open the appropriate swf files.
or
you can install swf opener software to open these files and view the flash and animated files.
2answers
.swf files don't run
.swf files are Flash files and are played by the Adobe Flash Player. If you currently have the Adobe Flash Player installed, try going to Start --> Control Panel and clicking on Add/Remove Programs. When the screen loads click on Adobe Flash Player and click Uninstall. Finally restart your computer.
When the computer reboots, use the below link to install Adobe Flash Player.
http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash&promoid=BUIGP
Thanks for your question!
3answers
I'm trying to open a .swf. What pogram do I use for it?
Its a flash file
http://www.fileinfo.net/extension/swf
use adobe flash (in a browser for example) to open it
Top Macromedia Computers & Internet Experts
ExpressFiX
ExpressFiX
Rob Hill
Rob Hill
Are you a Macromedia Computer and Internet Expert? Answer questions, earn points and help others
