If your other lenses lock on to all of the bodies, then it is quite likely that the notch on the mount edge of the 400mm is worn. The notch is located about 90 degrees clockwise from the red marker dot on the lens barrel. I doubt if there are new replacement mounts for that lens. You may be able to square up the edges of the notch with a small file.
