Avocent SwitchView 2-port KVM Switch Logo
Posted on Jan 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
XP Display turns off after switching to Win 7
Bought an Avocent Switchview DVI KVM.
XP Display turns off after switching to Win 7 display
The XP machine an an ATI RADEON x600 card
The Window7 machine has an ATI RADEON HD 4350.
When setting up the switch, I go back and forth -- the Windows 7 machine always displays, the XP machine never displays after the switch has been used.
Peter Parker
Level 2:
  • Expert 60 Answers
  • Posted on May 11, 2011
Peter Parker
Expert
Level 2:
Answers
60
Questions
0
Helped
36375
Points
121
Search for WIN 7 & KVM switch issues... you will find thousand of hits, because WIN 7 has one unique feature where it disables internal and external ports if these are not in use.
In a KVM solution setup this would mean, while you are connected everything is fine, now when you switch over to your (Lets say) WIN XP and work for 30 minutes on it... and then switch back, WIN 7 might have already scanned and seen that the USB port where the KVM cable comes in is IDLE... so it disconnected it... you cannot get it back until you reboot your WIN 7 system. Its not the KVM solution is one of those Microsoft wonder weapons that breaks what has worked for 20 years
Dell dimension 5100
If you are having problems with your video card
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers or
you might need to download one
http://download.cnet.com/video-ati-ati-radeon/3000-2108_4-175861.html
This package supports the following driver models:
  • 128MB ATI RADEON X600 SE
  • 128MB ATI RADEON X600 SE Secondary
  • 256MB ATI RADEON X600
  • 256MB ATI RADEON X600 Secondary
  • RADEON X300 SE 128MB HyperMemory
  • RADEON X300 SE 128MB HyperMemory Secondary
  • RADEON X300 Series
  • RADEON X300 Series Secondary
  • RADEON X600 256MB HyperMemory
  • RADEON X600 256MB HyperMemory Secondary
  • 128MB ATI Radeon X1300
  • 128MB ATI Radeon X1300 Secondary
  • 256MB ATI Radeon X1300PRO
  • 256MB ATI Radeon X1300PRO Secondary
  • ATI Radeon Xpress 1100
  • ATI PCI Express (3GIO) Filter Driver
Hope this helps you
I have a video card radeon hd 2400 series for vista 64 bit compatibility, will it work on xp 32? what can i do to make it work?
Hi There,
Yes it will work with Windows XP operating system.
1. If you're going to change the Vista operating system to WIN XP 32bit, you have to find WIN XP 32bit drivers for *********** board as well as the HD2400. Install Xp 32 bit
2. For HD 2400 drivers just click the link. ATI The link includes Catalyst, OpenCL and Display drivers.
3. Wait for the download to finish, Run the 32bit display driver and follow onscreen messages reboot if prompted.
A. If you're going to use it in another machine just download the display driver and attach the graphic card.
Hopefully this information helps.
Thank you for using FixYa.
Avocent KVM switch keeps turning off and on, blinking, then turning itself off again. Is it in a display mode??? When it comes up, it will display the video output from the computer. KVM...
the switch should beep if you switch between channels or Ports.
It seems that you might want to download the manual and try to reset the unit. If this doesn't work call their support. Avocent has free support as far as I know.
Hi, i have a Avocent SwitchView, Tried connecting to a user Monitor, KYB and Mouse then connected two monitor cables in A and B. Nothing seemd to be displayed. By the way i didn;t connect the power.
Hi Steven,
the power is or will be needed. Your unit is a single monitor... are you trying to make it a dual screen setup?
What is the target OS... ? How are you connecting *(USB or PS2) to the PC?
-If you use PS2 you might have to reboot your PC
Is the PC DVI or VGA?
I hope that helps getting you up and running
I have avocent switchview 1000 8 port. it has been working ok for over a year. On monday I found that 4 computers are not displaying 2 windows 2003 server, 1 windows 2008 and 1 xp. I have tried switching...
What resolution are you using? And if you place the Avocent KVM cable to a different port, do you get a signal? If you use a Known good cable do you get a KVM session with good video?
1helpful
I can't seem to find the driver for the ATI radeon x600 128mb PCI-e since the Catalyst Control Center wont install for me
download the updated driver from the lick given below...
for xp 32 and 64 bit
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/10-2_legacy_xp32-64_dd_ccc.exe
for win 7 32 and 64 bit
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/10-2_legacy_vista32-64_dd_ccc.exe
I need to download ATI Display drivers for my Toshiba tecra S211 but i m not getting it on the net
ATI uses drivers called Catalyst Drivers. The ATI card you have is the ATI Mobility Radeon X600. Go to this link;
http://ati.amd.com/support/driver.html
Select your Vista or XP or whatever your Operating System is from the first list. Then in the second list, select mobiltiy radeon. Then Mobility Radeon X600 from the third list. Then click GO.
Then on the next page use the installation verification software. Once it verifys your hardware is compatible with the driver, it should download and install it.
2answers
Lost driver
ATI display driver
Here is ATI multi driver: Click to Download
From AMD: "This is he ATI Radeon Catalyst Display Driver version 7.10 For WindowsXP/MCE, released by Advanced Micro Devices(AMD). This release updatesthe AMD Display Driver to version 8.401, supports all Radeon Desktopproducts(ATI Radeon9550/9600/9700/9800/X300/X550/X600/X700/X800/X850/X1300/X1600/X1650/X1800/X1900/X1950/HD2400/HD 2600/HD 2900 XT). This unified driver has been further enhancedto provide the highest level of power, and reliability."
Top Avocent Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Avocent Computer and Internet Expert? Answer questions, earn points and help others
