I have a Wurlitzer Omni 3000 Keyboard computer (organ) and the top 13 keys on top and bottom boards don't work, but everything else does. Again this the Very Highest C note to the next lowest C... Is there a fuze or loose connection that I could check out? I have the back of it off and have been looking for burnt fuses or a disconnected clip, but with no luck. Thanks, Mike
Those notes are likely scanned along with all the others. The strobe selection lines for those are likely failed... this might be only two wires.
IF you have ribbon style cables in the unit, this is often caused when people pull the cables by the edges to remove from connectors.
Look for this and a connector that might have one end lifted where a couple wires aren't quite connecting. THIS IS not ANY ISSUE OF FUSES.
