You need to plug it up to a USB 2.0 port not on a USB 1.1. There are many instructions to tell whether your USB is a 1 or 2 version but USB ports on the back usually are USB2 versions than the USB port on the front of your CPU.
The difference between both USB 1 and 2 for your Portable HDD is that USB 1 only uses 5volts power rather than the USB 2 which uses 8volts to properly revolce your SATA HDD.
Hope this helps. Thank you for using Fixya.
http://download.cnet.com/minitool-partition-wizard-home/3000-2094_4-10962200.html
A full-featured disk management utility is something most experienced Windows users need, whether it's to add and format a new hard drive, configure a USB drive, or copy partitions or whole drives and move them to new drives.
Freeware
Hope this helps
