We have a panasonic pt-43LCX64 tv that we've owned for 5 years with a rather large u-shaped yellow tint. My husband said it looks like there might be a heat defect in the lens (he surmises that's what it is called.) Changing the light lamp does not change the yellow image. Can this part be replaced by us and what is the usual cost? It's a matter of fixing this TV or buying a new one. Thanks
Improper white balance adjustment. adjust it properly. http://schematicscom.blogspot.com/
http://elektrotricks.blogspot.com/
http://electrotechnician.blogspot.com/
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
Please visit these sites to get some details.
SOURCE: panasonic pt-51g42v
You might have bad solder joints on the vertical output IC. I do not know where it is located in this set only that it will be mounted on a metal heat sink near three wires that have identical plugs which go to the deflection yokes on each crt tube. Sets vary as to placement of vertical IC. Solder joints should be easily seen if you have good eyes or use a magnifying glass. I do know that the vertical IC will be on the board that has the highvoltage transformer on it (has big red wire). You may have to unplug the board and turn it to the soldered side or just turn the entire chassis up 90 degrees to see the connections. If this is not the problem I don't know how to get into the service mode at this time.Hope this helps
SOURCE: Panasonic large screen Model # PT-61LCX65
Here is the proceedure to replace the lamp and reset the lamp hours.
Lamp Replacement Procedure:
1. Press the POWER button to turn off the power.
2. Wait for about 1 minute until the cooling fan stops.
Note:
The lamp cooling fan will continue to operate for about 1
minute after the power is turned off. Do not unplug the AC
Cord from the outlet until the fan has stopped. Avoid
interrupting the power by using circuit breakers or switchable
power strips.
3. After the cooling fan has stopped, unplug the AC Cord from
the outlet.
Note:
Please wait more than one hour before replacing the lamp.
[ Forced cooling function ]
If you need to replace the lamp more urgently:
- The Projection display has a forced cooling feature.
After the POWER button is turned OFF, and during the
first minute of the normal cooling fan operation, press
the VOLUME UP button on the unit and CH UP key on
the remote at the same time for more than 5 seconds.
The cooling fan operates for about 10 minutes. (LAMP
LED will flash 5 times every 5 second and POWER LED
will flash red for 10 minutes.)
4. Remove the Front Cover Unit from the latches.
5. Turn the Knob to the left.
6. Pull the Lamp Cover out.
7. Loosen the Screw on the Lamp. Then, pull the Lamp.
Note:
Because the Lamp may still be hot, use caution when
handling.
8. Install the new Lamp, and tighten the Screw.
9. Install the Lamp Cover, and turn the Knob to the right.
10. Install the Front Cover Unit.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
SOURCE: TV Won't Turn On
the lamp is bad. panasonic has a 5 year part warranty on the lamp and 2 years labor
SOURCE: PT-61DLX75 replace lamp light reset
To reset the lamp timer, turn the TV on first. Now hold VOL DOWN on the TV and MUTE on the remote until a message appears on the screen about the lamp timer being reset. Make sure the remote is pointed toward the TV to receive the signal.
