Nokia 6500 Slide Cellular Phone Logo
Posted on Nov 11, 2009
I have Nokia 6500 slide and suddenly it started to freeze without apparent reason. I need to pull out battery and wait for couple of minutes and then it can be turn on. However, after a while it freezes again. I upgraded the software but it didn't helped.
Anonymous
Level 1:
  • Contributor 30 Answers
  • Posted on Nov 11, 2009
Anonymous
Contributor
Level 1:
Answers
30
Questions
0
Helped
6455
Points
88
Okay so u hav tried hard bt v r really sorry to say that the problme is that mostly 6500 slide has dis unique problem . its company's deal however. we wish u had buyed another model. but if u get it reformatted instead of updating software it will work
3helpful
How i unlock my nokia 6500 slide ?
There are lot of ways to Unlock the Phone from Network lock,But i suggest the Network Unlock code to unlock the Phone from Network ,you can get the unlock code at here
Mobile-Unlocker and follow the instructions below and unlock it step by step.....
1 - Switch on your Nokia 6500 SLIDE without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6500 SLIDE.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6500 SLIDE would then display the message "SIM Restriction Off" and will be unlocked!
Unlocking instructions for Nokia 6500 SLIDE:
Note :For Nokia 6500 SLIDE mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6500 SLIDE
Hi dear suddenly my nokia phone is locked it says security code...what do i do?
Hello Monir,
Switch off the phone.
Remove the battery for 30 minutes.
Reinsert the battery and switch on the phone.
Enter the default code 12345.
Your phone will be unlocked
1helpful
Nokia 6500 Slide\r\nMy fone had nearly full battery only last night and then it all of a sudden turned off.... i put it on to charge but it wouldnt ... so i put the battery in another of this same fone and...
your phones software is corrupted and to reprogram to fix it..an expert mobile repairman will help you...but you must pick a trusted one who have knowledge and expert in using software gadget..
he must be having this gadget ,mx key dongle or cyclone box because this gadget can save all your data and can reprogram your phone without losing a single bytes..
i hope it will help ,thanks
Nokia 6500 slide. turns off after about 4 minutes
its either a battery or software problem.
Test the phone with another battery. And if its not a battery problem, then it should be a software problem. Maybe you should flash the phone.
Take care.
4helpful
2answers
My nokia 6500 i turned off and was work fine before,now
its a software problem. I think the software files are corrupt and that's why the phone cannot boot.
The phone needs to be reformatted for it to work properly again. The process is called Flashing.
That's the only way your phone could be revived.
Take care.
Nokia 6500 Slide. Wired headset - no sound.
brother i have also the same problem what i can do?
please help me
Cannot switch off my nokia 6500 slide.
You must have updated the firmware yourself. Go to Nokia Care and get it done there. When they do it, the complete firmware is removed and reinstalled. When you do it only the new files are changed.
1helpful
3answers
My Nokia 6500 is not getting switched on
its problem flex if u change flex everything will be fine
or contact me [email protected]
1helpful
2answers
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
