Fish Logo
SATISH DEVISETTI Posted on Jun 06, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello.. Is this arrangement of blue and red sponges correct? When I switched On, water is spilling out.
ADMIN Andrew
Level 3:
Top Expert:
  • Master 66,980 Answers
  • Posted on Jun 06, 2021
ADMIN Andrew
Master
Level 3:
Top Expert:
Answers
66980
Questions
Helped
5089856
Points
379943
Looks like a Pond Filter or a Pool Filter, so I moved you from Office Supplies Category.
Google make model manual
Or tell me and I can find the information. Click COMMENT under my post.
How do I clean my keyboard on toughbook cf53. I spilled juice on it and the keys are sticking and hard to use now.
It is a toughbook so don't be afraid to use a damp sponge to try and clean out the sticky sugarly juice. Increase the amount of water in the sponge as you go along until it gets clean enough to work correctly. Leave the laptop upside down while doing this to prevent the water from carrying the juice further into the keyboard. If you know how to remove the keyboard, I've successfully washed it with running water and letting it dry out vertically so excess water runs out to an edge. If the heating system is on, I've done this on a radiator or heating vent.
tip
SOME USEFUL KITCHEN TIPS.....!!!
1) To get much cleaner and sparkling dishes just add few tablespoons of VINEGAR to your
dish-washing detergent....Vinegar is a master in cutting of the grease that helps in getting sparkling dishes easily.
2) To clean the spills in Oven just sprinkle some salt over hem immediately. After the oven has cooled
down, brush away the spills with damp cloth.
3) Smelly sponges are a real mess....to clean them just clean them properly and thoroughly and then microwave it
while its wet. Once you see steam arising from the sponge take it out...and be CAREFUL as it will be too hot.
Wash before reusing it, with water. Be sure that there are no METAL components in the sponge.
4) For removing lime build up and hard water from a teapot, just add 1-2 cups vinegar to some water in
teapot and bring it to nice boil. Sim for 10 minutes and then rinse it out.
5) OLD STAINED SINK....To clean and whiten it just add half cup of salt in it and then scrub it
with a lemon over it to get a sparkling sink as new.
on Apr 09, 2010 • Microwave Ovens
1helpful
How to clean a fushigi
Use a small brush or use a vacuum cleaner to dust it. Clean spills quickly therefore you need to clean up anything that is spilled onto it quickly. Make sure that you wipe it with a sponge and use soapy water. Keep it out of the rain and direct sunlight. Clean it properly by mixing a basic solution ...
Red wine stain on my carrera white marble counter. Red ring what will take of the color?
Red wine on your carrera white marble. You need 1/2 water and 1/2 Stain Rx. Apply with a sponge or rag and rinse off all the soapy residue with water. Gone as fast as it was spilled.
Aug 23, 2011 • Home
INtermatic Model ST01 timer is to be used in a 3 way switch arrangement. The unit works in one switch position but fails to allow the light to turn on in the other switch position. Several other switches...
ST01C timer replaces one 3-way switch and the other 3-way switch remains.
The ST01C timer does not work exactly like a 3-way switch.
When the timer blue and red wires are connected together, they reverse whatever program is in effect.
When the timer is wired for single-pole, the red wire is capped off. When timer is wired for 3-way, the red wire is used to reverse the timer, thus causing the 3-way effect.
So if timer is ON, and red and blue wires are put together, the timer turns OFF.
That's why the remaining 3-way switch has to be rewired.
The remaining 3-way switch is rewired so it will connect and disconnect the red and blue wires, causing the timer to reverse program each time, and creating 3-way effect.
Other requirements of ST01C is that the black wire must connect to Hot wire, and the blue wire must always connect to Load. This means that you have to correctly pick which 3-way switch to replace, where the hot wire from breaker arrives.
Open following link for wiring diagram showing how to wire for 3-way:
http://waterheatertimer.org/ST01C-program.html#ST01C
All 3-way timers require rewiring second 3-way switch to create 3-way effect.
2answers
1helpful
2answers
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Map sensor pin arrangement dodge cavan 2003
Hello, here is a picture of the connector and wiring.
85cdf8a.gif MANIFOLD ABSOLUTE PRESSURE SENSOR (GAS) - BLACK 3 WAY CAV CIRCUIT FUNCTION 1 K1 18VT/BR (3.3L/3.8L) MANIFOLD ABSOLUTE PRESSURE SENSOR SIGNAL 1 K1 18VT/BR (2.4L) MAP SIGNAL 2 K900 18DB/DG SENSOR GROUND 3 F855 18PK/YL 5 VOLT SUPPLY
Pink/Yellow is #3, Blue is #2, and Purple is #1. Your colors may appear slightly different
Top Fish Experts
Keith
Level 1 Expert
ADMIN Andrew
ADMIN Andrew
Are you a Fish Expert? Answer questions, earn points and help others
