I have tried the YouTube instruction for Magura RT8 TT with not much success. And unlike the Shimano hydraulic system, there is no valve/nipple on the brake caliper to close/open to test if pressure is building up ok. The Quick Release system also makes it complicated to test and bleed the system.
I came across similar challenge when trying to fit the Magura RT8 TT brakes on my road bike with the Shimano Dura Ace levers. So converting to RT8C is a nice way to enable hydraulic rim braking with my normal cable operated road levers.
The original PDF instructions does not mention much about the RT8C as it is geared towards RT8 TT. The YouTube video is also for RT8 TT, not useful for RT8C.
Having tried half a dozen times with different techniques, I finally found a way that works and it works consistently each and every time. And I am happy to share this with others. Hopefully this would reduce the level of frustration involved when trying to bleed a RT8C system, as this as simple as a Shimano or SRAM hydraulic brake.
You would need to Magura Pro Bleed Kit to complete this procedure.
Here is the procedure I follow:
Hope you would find this helpful.
Testimonial: "Thank you very much for the instructions. It works perfectly."
once you have done the bleed you can fine tune your pad position with two hex screws behind the front cover I usually back these out a few turns before bleeding. DONT back them all the way out or in as they will drop off the captive nut on top of the piston and you will never get them back in 3 turns either way should be fine just watch the screw and the plate it mounts in
Its a pity Magura provided useless instructions with these brakes they a great upgrade for older frames without disc or direct mount
SOURCE: 1986 gmc sierra 1500 front rt brake locks up
check brake lines they may have gotten pinched very commonok new c/k trucks when you crank the torsion bars up to far you may have hit something and pinched the brake line check those before messing with the master cylinder those are a real pain
SOURCE: no brakes
Check the Brake master pump......If the padle drops to the floor means The booter is ok,,,,! I think the Brake master pump has a internal leak.....Reply me.....
SOURCE: replced front brake pads and calipers adjusted
Bleed the master cylinder first. You have to do that before you belled any calipers or wheel cylinder.
SOURCE: location of brake/clutch bleed valve nipple
AHH look for it by the slave cylinder it might have a black rubber cap on it to keep dust out it will look simliar to the bleeder valve on the brake system
SOURCE: suzuki Vitara front brakes seizing intermitantely.
Be sure you have changed the break oil completely. Otherwise drain the hydraulic system and renew with correct type of oil. If you have a ABS system you have to check that also.
