Code U61 will nto reset. Turn DVD off and then when switched back on says Please Wait for ages and will not configure
You have the same issue as the one who is posted here at Fixya. But this requires you to open the DVD cover. If the unit is still under warranty, its best to bring it to the authorized service center. If not, you can try and test this if it'll work.
http://www.fixya.com/support/t221217-u61_error_code
"I have the same problem (same error # same model of DVR).
I noticed it happened after I left a DVD in play mode and paused for a long time.
I saw a message on the Internet that error U61 can mean that the lens is unable to move (return to its normal position).
The
Internet message said that person unpluged everything, then opened the
cover to the DMR-ES15 (3 screws) and gently pushed the DVD head back
towards the rear of the DMR-ES15.
I assume that would void his
warranty, but I am considering trying it since the time to have it
repaired versus the replacement cost makes the possibility of a
"self-repair" attractive.
Here is part of that actual Internet message. I hope it helps you:
Yesterday, my DMR-ES15 started to malfunction, giving me the error U61.
No matter how many times I tried to press Enter, and Power On, the machine
kept
re-booting with the error U61. I noticed that the drive was making some
noises as if the Read head was not able to park properly.
So I decided to open up the unit and find out why.
I took out the 3 screws holding the top in place. And then moved
the drive head mechanism back (pushed it towards the back of the unit).
I then plugged the power in, turned it on, and amazingly there was no more U61 error.
I test the unit this morning again and everything seems to work properly again!"
