I set up a charity org FB, which posts were in my personal FB before. Now I am trying to copy to the new FB that I opened recently. While I continue to copy posts one after the other I received the message.It was stated that was a mistake.
SOURCE: Automated Document Feeder Problem
It sound like the paper is not getting recognised by the original sensor. Check for an obstruction in the feedpath - piece of paper, paper clip, pin, cockroach, apple core, tube of cake decorator (I've seen it all). Do this by opening the control panel cover (the one you open when you replace your cartridge and look through where the original feeds. Also see if the original sensor arm is in place. In the white plate there will be a black arm. The original sensor arm will be directly behind this sensor.
SOURCE: samsung sgh-a707 cellphone, blocked calls
go to settings, then call settings, then all calls and you should be able to help yourself from there
SOURCE: Cannot copy Outlook pst file to flash drive, somethings blocking it
hello
in this case there might be a software installed on your pc that is resticting you to copy that
like point sec is a s/w that will restrict you
in this case what you can do you can uninstall the s/w or bypass the s/w by not typing just ignoring that options
SOURCE: Cannot fax or copy message is check scanning area
Take out the cover that covers your recieving paper and look in there!U will c a smallish black handle with a green sticker on,pull it down gentle and push it up untill it clips into place!Good Luck!
SOURCE: Facebook blocked my account. Why doesn't FB tell
there are reasons why someones account suddenly blocked by Facebook and sometimes they were not informed. Facebook system has gone to being strict in monitoring activities happening inside a person's account. (You are right. They are monitoring all facebook users)
Why? Because of spamming and phishing. Its like a virus that a person's account once infected will send spams on all of its friends. Imagine how many persons there are in a friends list.
However Facebook sometimes mistaken some activities in an account. When someone sends somethings on a group of friends and someone adds a large number of friends, Facebook mistaken it as a spam.
If you are wanting to unblock your account send an email to [email protected]. State your reasons why you should be unblock. Ask also the reasons why they block your account. So it will be a reminder for you to prevent your account from being block again. Remember, facebook will unblock account only once, so better be careful.
Let me know if this is a help to you.
Thank You for using Fixya!
