Garden Logo
R
Ron Giret Posted on Apr 18, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How wet does a spark plug have to get before it fires on a weedeater 25cc i have compression and spark . It fires but doesn't keep runnin
CJ Rock
Level 3:
  • Weedeater Master 4,429 Answers
  • Posted on Apr 18, 2019
CJ Rock
Weedeater Master
Level 3:
Answers
4429
Questions
0
Helped
1645504
Points
15024
With out the choke, the plug is not likely to have visible fuel condensate. If after priming it fires, sputters and dies then likely there's a problem with fuel delivery. If you're using fuel more than a month old, replace with new fuel (fresh from pump) and mix.
Check the following
  • Cracked fuel line(s)
  • Fuel filter
  • Cracked primer bulb (may not be visible so replace)
  • Carburetor mounting has become loose (vacuum leak)
  • Carburetor gasket or adapter is cracked
If still doesn't run, then likely the carb needs a clean/rebuild or replace. You could try Seafoam (or similar) additive. There's also a possibility of a crankcase leak.
Keep in mind a china duplicate replacement carburetor for this unit is ~ $10, delivery included (USA), from Ebay or Amazon.
5 Related Answers
Anonymous
  • 87 Answers
  • Posted on Apr 11, 2009
SOURCE: WHAT IS THE SPARK GAP ON 25CC HOMELITE WEEDEATER
Gap is set to .030
Dwain Pippen
  • 377 Answers
  • Posted on Jun 08, 2009
SOURCE: What should the spark plug gap be on a weedeater
Set it at .025
Anonymous
  • 67 Answers
  • Posted on Sep 22, 2009
SOURCE: 25cc TB25BP new plug, new Gas, Clean Carb.. will not start
Check Make sure its the right plug.- Check for stuck choke-Check.Air/fuel mixture screws out of adjustment.
CarMech97
Steven A
  • 427 Answers
  • Posted on Oct 07, 2009
SOURCE: 2002 escape miss fire on cylinder one
power not reaching cylinder 1 ignition coil. check electrical connections and wiring for any damage. test for power and ground at cylinder 1.
hope this helps.
rycgl
Roy Cagle
  • 1545 Answers
  • Posted on Aug 21, 2010
SOURCE: weedeater 25cc electolux motor does
Make sure when you test for spark, you use a spark tester or at least ground the base of the plug to the engine when you use the pull start. A strong little blue spark should be present. The airgap between the coil and the flywheel may need to be adjusted. The specs are about .010-.016" or the thickness of a regular business card. You would have to loosen the two coil screws on the back of the engine's cylinder if you have checked and determined it actually needs adjusting. Covers will be have to removed to get to this location. Torx head screws hold everything on these together.
Testimonial: "This tip has pointed me in a sound direction to fix the blower!"
Craftsman 25cc weedeater quit running whie using it. Filled it with gas, would not start. Poured gas in the carburater, used starting fuid, spark plug firing, still would not fire. Any ideas?
If it has compression and spark it has to be gas. Try a new plug. If it still does not start consider replacing the carb. About $14 fro m Ebay. Make sure to replace the fuel lines going into tank. They come with a carb kit usually.
My hand held blower wont spark plug and carb.replaced still wont start
If the plug is wet with fuel and it is firing then pull the muffler and for a struck ring. Struck and bad score cylinders will cause one not to start as you need at least 100 psi of compression to ignite the fuel mix.
These are okay then check the ignition of the flywheel to coil relationship as it could be a sheared flywheel key. Note most 2 cycles are now using cast in key as part of the flywheel itself.
How come no spark?
I would change the plug first and check to see if the coil is firing by grounding out the plug and see if there is fire. If not the ignition coil or unit maybe bad. Hope this helps.
Stihl sf44 weedeater wont fire
more info please? does it now have a spark and good compression?
Only runs on choke
fit a diaphragm kit in the carby
the pump diaphragm is the first to fail and then the float diaphragm distorts and will not let in enough fuel to keep it running
My weedeater want start change spark plug
I would have a cylinder compression done on the engine before spending any more money. It may be below 100 psi and will not run. Plus if your fuel mixture is over 30 days old I would mix up some fresh fuel mixture.
Or the diaphragm in the carburetor has become stiff and is not pumping any fuel.
Good Day.
3helpful
It keeps stalling after only a few minures
Suspect Ignition Coil is failing under heat.
To test this, take the unit outdoors and have a fire extinguisher handy. Start and allow unit to run until it shuts down. Then remove spark plug and test for spark by grounding the outer shell of the plug on the engine's metal surface.
BE SAFE!
Keep your face away from the spark plug hole as you pull the rope to test for spark. Expelled fuel or vapors can ignite via the removed spark plug or any subsequent arc.
If no spark when hot, and good spark when cold, replace ignition coil.
Find your EXACT model number on your unit, then go HERE to lookup the part number of the coil. Call your local reputable repair shop and ask if they have it in stock or can order for you.
Hope this helps.
3helpful
Weedeater will not start. was running, shut it off and then will not crank. I have checked all the obvious(spark plug and wire, has good fire, fuel filter and lines,took apart carb and cleaned good) still...
Pull the spark plug after pushing the primer bulb and cranking a few times...if the plug is "wet" (indicating fuel is present in the cylinder) then the next step will be checking the compression...compression should read above 90psi (preferrably 100-125psi)...if compression is below 90psi, the most likely culprit will be a stuck piston ring.
Top Weedeater Garden Experts
vince
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
