If you are having these problem with your nokia, there are two possible reasons why this should be happening;
1. You could be charging it with a faulty charger, and you should get another e71 charger for it. You can probably use this same presumed faulty charger on another nokia phone and if it does work well then it implies that the charger is fit and well. So please don't replace the charger.
2. This therefore leaves us with the last option which is the battery, please replace the battery you've got and your phone would charge normally.
Hope this helps as i presume that your charging port is very much ok.
Regards
