I have taken it apart to check connections, but still overheating. Too hot to touch. Any ideas what else to check?
Danger do not store this bad hot phone
anywhere where, fire would be devastating, (home , car, ?)
i'd put in the fire place, on bricks, (but not for long, just long enough to seek help)
for sure put it out doors is better, safer.
like inside the BBQ. is safe.
what we do is remove the battery proto. (RIP mr. battery)
newer batteries are now have fuses,to stop fire.
get it out of there now.
google cell phone fires. and learn.
The battery may be damaged. If this is the case, then the unit could burn or explode. The other issue is that the CPU heat spreader bent and is no longer in good contact or the tablet isn't getting good circulation near the various chips inside.
I would also check the wiring for shorts (wires touching each other) when the case is closed. The wires in tablets are often fragile and will heat if too much current flows through them.
I hope this helps.
SOURCE: Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
SOURCE: TKC 8522/2 top oven outer door shattering
the glass would only shatter if it was installed backwards but then it would of shattered a long time ago it shattered due to a scratch on the glass or the door was damaged
SOURCE: how to connect my samsung
how to connect my samsung led tv to samsung galaxy tab through all share
SOURCE: My Samsung galaxy s phone won't play any videos
,U shud convert the video files first in the supported format of ur phone..read the manual to see which formats are supported..th,,,,,,,,,,,,,,
