I dropped it in water and it has been working fine, I quickly got it out and dried it off. It started just vibrating, so i rebooted it and it won't come back off and still vibrates.
SOURCE: Stop the Vibrating
Sounds like the phone may have gotten wet. Check behind the battery for a white circle sticker, it will be red if the phone has gotten wet. Best of Luck.
SOURCE: dropped phone in water
My Motorola razr went through 2 cycles of washing machine! I fixed it by removing the battery first, letting it thoroughly dry out using a cold setting on a hair dryer, after opening the battery compartment, folding open the phone and even a bit of sundrying, Another gentler method of drying it is by leaving it on a
UPS system where the temperature wont exceed 45C or so. I was careful not to turn it on soon after I picked it up from the washing machine.
I have heard- but havent tried it- of people successfully using WD20 or one of those silicone sprays on electronic items to dry them out.
SOURCE: white screen on samsung sch-r450 messenger frm water damage
the only possible thing you could do yourself is to remove the screws, pull it apart and try to blow dry. That's the only thing you can personally do.
SOURCE: phone got wet stuck on download screen & vibrates
the phone needs service, when it got wet it damaged the mother board of the phone.
SOURCE: Loud Vibration/Noise when System Starts
This happen when there is air in the gas line...if the problem is still there after a couple of days you will have to return the unit for an exchange the gas control is giving problem...contact rheem first before making a exchange decision..they will walk you some step first to ensure there is not a problem
