Banish Ants with Betel Leaf Betel leaf is often found as a fracture (chewed-chewed) by parents of old. Usually used to keep teeth durable. Apparently the leaves of this one plant is also able to mengtasi ant problem at home. You only need to use a few pieces of kneaded leaves to remove the scent. The aroma is so hated by the ants that they will stay away from the area of betel leaf squeeze. Overcoming Ants with Coffee Powder If we humans generally love coffee then not so with ants. The ants do not like the name of coffee especially in the form of powder. How to repel ants using this coffee powder is quite easy. Just by sprinkling coffee powder on the area we want to avoid touching the ants then they will stay away from it. It can also be sprinkled in the ant's nest so they run away forever. Expelling Ants with Cucumber There are interesting facts that you need to know about ants. Generally these colonized insects are not very happy with the name cucumber. So by placing a cucumber slice on the ant nest will get them going. Can also by putya in the path of the ants passed blinded mice. Dispose of Ants Using Salt How to repel the next ant that is utilizing one of the kitchen ingredients that is salt. Salty salt taste so disturbing ants that they will avoid it. How to use salt to repel ants can be mixed with warm water and sprayed into ant nests or areas that want to be shunned by ants.
Borax is first what comes to my mind when talking about insects especially garden pests. Diatomaceous earth is also a well-known insect repellent, ants and sandgroppers can't stand it. They're similar at this point. You can also get dusted traps like this https://pestcontrolhacks.com/top-6-best-ant-traps-reviewed-how-to-choose-the-ant-trap-to-solve-your-problem and spread it at the borders of your garden.
There is nothing best than a homemade product or item. Like another item, you can also make and apply homemade ant poison to invade their existence. All you just need some borax powder and some other elements. You can naturally collect borax from lakes and then blend it with honey. Now keep the mixture in different corners of your house. Ants will attract and consume. Then it transfers the bora back to their colony. Thus you can rid of ant problems by using homemade ant repellent. Moreover, you can get the borax powder to your nearest supermarket or shops.
Ant Traps Spray
