SOURCE: 2006 nissan murano headlight out
Bulb can be replaced. You can buy at Walmart or your local parts store. I recommend replacing both. They are rated for the same amount of run hours and will usually fail within the same month.
You can also buy from this link.
http://www.partsgeek.com/gbproducts/YN/B18919-HEL-P8040.html?utm_source=google&utm_medium=ff&utm_term=06+2006+Nissan+Murano+Headlight+Bulb+Hella+Nissan+Headlight+Bulb&utm_content=YN&utm_campaign=PartsGeek+Google+Base
SOURCE: how to reset service engine light on 2006 nissan murano
generally you just unhook the battery for about 15 minutes and hook it back up... if you have an anti-theft radio... make sure you know the code and how to enter it.
SOURCE: trying to change the cabin air filter
1. Open glove box
2. Unhook elastic retainer on right side
3. Locate the two "stop tabs", one on the upper left and the other on the right side. Push both to the left to clear their stops and the glove box will swing down, allowing access to the filter cover.
SOURCE: how to change 2006 Nissan Pathfinder microcabin filter
To change the cabin air filters (there are two, that are in same location), you first have to remove the glovebox. The glovebox itself will not come off. You have to get a phillips head screwdriver to remove the 5 screws. With the glovebox closed, locate the two screws underneath and remove, one on each side. Next open the glovebox, remove the two screws at the top. The fifth screw is on the right behind the plastic molding. Pull back on the top of the lower piece of molding until the bracket pops out. The piece of plastic located just above that piece needs to be pulled out. No need to take it out all the way, just enough to get to the screw. Once removed, with the glovebox open take the fuse panel cover to the right off to allow you better grip. Pull both sides evenly until glove box pops out.
Get a flashlight and shine it on the right side behind where the glovebox was. There is a small plastic cover about 1 inch tall by 5 inches long. It is clipped in place. Push up on the plastic clip with your thumb while pulling out and down with your other finger/fingers. Behind this is one filter. Remove it best you can. Be careful, mine had dead bee's/wasps/dust/dirt/pinestraw/etc. After removing the first, you will notice a second one to the right of that. Slide that one to the left and remove the same way as the first. Look at those filters when you remove and take note the direction of AIR FLOW ^marking. Before replacing with the new ones, vacuum out inside where the filters go as best you can to remove all that crud that fell off of the old filters when removed.
Reinstallation is the reverse of how you removed. I hope this helps all my fellow Pathfinders out there.
SOURCE: How do I find a fuse box diagram for a 2006 Nissan Murano
FIRST REMEMBER THERE ARE SEVERAL FUSE BOXES.. NORMALLY THE CIG FUSE IS IN THE UNDER HOOD POWER DISTRIBUTION CENTER OR FUSE BOX.... A VERY GOOD RULE OF THUMB I HAVE FOUND IS TO CHECK ALL THE FUSES IN THE FUSE BOX....THIS USUALLY PREVENTS CHECKING THE WRONG FUSE AND IT ONLY TAKES A SECOND TO DO IT
