I have provided an image that will assist you and it will connect like so;
1. Connection 1 should have the
Pos. (+) battery
cable and all of the wires with the large eyelet connectors from the wiring harness connected to it, except for the large cable that runs down to the starter.
2. Connection 2 should only have the large cable going down to the starter connected to it, and there should be no other wire connected there.
3. Connection 3 is the "S" terminal on the starter solenoid, and it is the wire with the small push on connector that is hot only when the key is in the "start" position, usually it is a red wire with a blue stripe, but that is not always the case.
4. Connection 4 is the "I" connection on the starter solenoid and it feeds current back into the ignition, and it is not used on a lot of vehicles after 1981, but if your
vehicle has it it will be a small push on connector that will not have any
power from it at all, and it will usually be a black wire with a white stripe, but that is not always so.
