Music Logo
James Fairchild Posted on Aug 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No sound but have power and signal on mackie Srm450v2. New amp?
  • James Fairchild
    James Fairchild Aug 05, 2016
    I have sound to the other speaker when the Thur is connected.
Sock Puppet
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Master 322 Answers
  • Posted on Aug 05, 2016
Sock Puppet
Master
Level 3:
Loyalty:
Answers
322
Questions
0
Helped
112882
Points
1777
There are repair services on ebay etc but not cheap.
2 Related Answers
Anonymous
  • 4234 Answers
  • Posted on Feb 10, 2011
SOURCE: Problem with Mackie SRM450V2: HFsignal
There is an entire crossover circuit inside that is BEFORE the amp section. There are 2 separate amps: one for HF and one for LF. Can you describe the noise you are hearing in more detail? Is hte sound effected by the gain controls at all? What happens without any input?
Thanks,
Dan
Fred Yearian
  • 5603 Answers
  • Posted on Apr 24, 2011
SOURCE: I have Mackie SRM450v2 speakers,
Chances are if the fuse has blown, there are failed electronic components that caused the failure.
Here is a service manual that will be CLOSE to your unit, though not exact:
http://elektrotanya.com/mackie_srm450_active_speaker.rar/download.html
Scroll down to the "Get Manual" on the site and click on the link. The file is compressed. The first part is the schematic, the second the assembly and parts list. Likely the main low freq power amp has shorted transistors.
Power supply circuit diagram
There is almost certainly a reason the PSU has blown, these are not very reliable units and the amp has probably gone and taken the PSU with it. You are better off taking it to a dealer and getting it fixed. If there is no power on the seecondary and there is no short the transformer must have blown (assuming you're not trying to check with a DC meter)
My speaker sounds like it is blown
take it to a Sound Production company and ask their opinion. If they use Mackie gear-even better. They will better be able to tell you what's goin' on if they hear the speaker. Good luck.
Mackie srm 450 very low volume
Make sure you are driving LINE LEVEL signals to this and not mic level signals.
No sound
This is not a powered mixer and so you must connect a power amp to the "line level" outputs of the mixer. Other "no output" problems could be related to buss assignments and other signal routing issues. Check for output by connecting "Main Out" left or right to a guitar amp input instead BUT turn all volumes down to zero before conductiong this test as guitar amps are designed for "Microphone" level inputs. Owners and Hookup manuals can be found here...
http://www.mackie.com/products/1604vlz3/
2answers
Problem with the Mackie SRM 450 v2
It would be very unusual if the blue LED is burned out. They should last a million years. I suspect the power supply has a problem.
What size internal fuse on mackie srm450v2 speaker
Mackie say this is not a user service part. If the fuse has blown there is probably a fault in the unit being their reasoning. I know for certain they tend to blow for no apparent reason so it is worth giving it a go. They are 5 x 20 Slow or time fuses. 7A for 120V and 4A for 230V
ONLY GETTING MUFFLED SOUND FROM ONE OF MY MACKIE SRM V2 SPEAKERS,HAVE CHANGED DIAPHRAM BUT PROBLEM STILL THERE
If you've changed the tweeter and the sound is still muffled the fault is with the HF amp, or the cross-over. You will have to send the amp assembly for repair as it is all surface mount components in there -nothing you will be able to fix yourself. Sorry for the bad news!
I have Mackie SRM450v2 speakers, one has no power, I think the fuse has blown, it it possible for me to change this myself? The manual says it's not user serviceable.
1helpful
Problem with Mackie SRM450V2: HFsignal bleeding through LF driver,low HF OUTPUT also. Filter problem i suspect.
Thanks,
Dan
Top Mackie Music Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Mackie Music Expert? Answer questions, earn points and help others
