Phone to Phone Transfer is the all-in-one yet professional data transfer tool which can transfer photos, contacts, music, videos, calendars, call logs, messages, apps and app data for you. It supports iPhone, Android Phone, Blackberry, Nokia, Windows Phone perfectly. With it, you can copy data from one phone to another without any difficulty. So, you can easily sync all your data from the old Huawei phone to Samsung Galaxy S8/S8+ by using this tool.
What do you need to transfer?
You can use android transfer app, which allows you to save a lot of time to transfer or backup text messages, contacts, photos, and other media files like videos, music files.
With the help of those backup tools, you can easily transfer files from android to computer.
Family Tree Maker has a Mac version of their software available on their website. This link also provides some possible solutions for your situation for converting PC version to Mac.
If you have any reason to not switch to the Mac version of Family Tree Maker, or have other PC software that may not not be available for Mac, there is an easy solution for this as well, but does require purchasing a copy of Windows. You can install Windows as a second operating system on your Mac to support those applications not compatible with Mac. This can be done using the built in "Bootcamp" utility on your Mac. This allows you to boot to any version of Windows or Linux, as well as your Mac OS. Another method is to install "Parallels" for Mac, which also allows you to install multiple operatings systems, but with the added ability to Mac OS X and Windows simultaneously.
Please note that your cable will support below givne O/S check at your end.
One destination PC running Windows 7 (32- or 64-bit) and available USB port
One source PC running Windows® XP (32- or 64-bit) or Windows Vista® (32- or 64-bit) and available USB port
For Example two Pcs 1 is Xp and other pcs is Windows 7, then try to connect between both .
Another one more option is there for transfering the data between two systems either laptop or Desktop by a cross cable (LAN CABLE), buy a cross cable from shop and insert into RJ45 Socket (i.e lan socket) the try to transfer the datas.
If this answer is helpful, please rate....
The Panasonic PV-GS12 will transfer video in video record mode and video playback mode using the DV connection (IEEE) Firewire port. PC Mode is restricted to memory card access via USB. If after connecting it in this manner if it does not work try this. With everything connected via firewire and iMovie running. switch the camera to PC mode and the import window should pop up. You may get a comunications error and if you do then switch to playback mode. The import window should stay open and you can control your camera with the iMovie controls.
