Karbonn K9 Logo
n
nasikoorad Posted on Aug 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ringer not working - Karbonn K9
Mark Brophy
Level 3:
Master:
  • Karbonn Master 752 Answers
  • Posted on Aug 30, 2015
Mark Brophy
Karbonn Master
Level 3:
Master:
Answers
752
Questions
0
Helped
137483
Points
2539
Either this is a settings issue, or your device needs to be serviced.
How to Ringer On of Panasonic KX-MB772
Before adjusting volume, set the operation mode to fax
mode (page 16).
Ringer volume
While the unit is idle, press {V} or {^}.
L If there are any documents in the document
entrance, you cannot adjust the volume. Confirm that
there are no documents in the entrance.
To turn the ringer OFF
Press {V} repeatedly to display "RINGER OFF= OK?".
i {SET}
L The unit will not ring.
L To turn the ringer back ON, press {^}.
Ringer pattern
L You can select one of 3 ringer patterns (feature #161
on page 50).
Monitor volume
While using the monitor, press {V} or {^}.
and if it work then say a thanks to your Pakistani Brother.
Hi anna i have a problem it is ringer is not working
Hi there
Go to menu,phone settings,ringer settings to check if your ringer is on or off,if it is off switch it on
If your ringer still isnt working then you should have your ringer changed.An expert or anyone with experience should be able to do that.
1helpful
Sony ericsson elm doest ring or vibrate when a call is comeing through
Hope the ringer and the ******** is enabled. If so there is a possibility that the output amp of the ringer is faulty which can also be linked to the ********.
You can reset the phone after removing the battery and setting it to default settings. If this wont work then it need a careful investigation in the output of the ringer.( test ringer if working)
Ringer is off/cannnot hear incoming calls - instructions does not include how to turn the ringer back on
hello,you have to go to your phone settings,then you go to the phone ringer settings,you then set the ringer settings to the step you wish.
that will make your phone ringer work as expected and supposed.
wish you good luck,
take care.
Aug 13, 2010 • Cell Phones
2helpful
2answers
One of my phone reads "ringer off" and I want it "on"
hello,
i believe have ringer on and ringer off.
press the menu, press the profile, then, choose a profile, personalize it.
when personalizing you will see ringer on and ringer off change it to ringer on and activate the profile. i am your phone will ring.
thanks for using our website
1helpful
The ringer no longer works on my Nokia 6585. Is it
There are no parts. per'ce, for this. the ringer function is electronic. Make sure you dont have the ringer turned down or off.
Dec 07, 2009 • Nokia 6585
2helpful
Need ringer turned back on .. radio shack 5.8GHz
Hit the up or down arrow keys several times. (either key will work) and the ringer will rotate through Ringer off - Ringer low - Ringer high... one set will be a steady ring, the other set will be a warble ring. This works on the phone made for RadioShack with 5.8 GHz on the front and Cat. No. 43-155 under the battery in the battery compartment.
43helpful
7answers
China mobile ringer problem
sigmatel s890 ringer not working pls give me a solution immedietly
Ringer and picture Id
The first thing you have to do is go into the settings and tools menu. Once there got to option 6, call settings then ringer ID make sure it's set to on and then do the same for picture ID. That should take care of the problem. Hope that helps!
Motorola W 490 individual ringtone
To assign a ring alert (ringer ID) to an entry:
Phonebook > entry, then press
Options > Edit Contact > Ringer ID > ringer name
Note: The Ringer ID option isn’t available for
entries stored on the SIM card.
To activate ringer IDs:
Settings > Ring Styles > style Detail
> Ringer IDs > On
Top Karbonn Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Karbonn Cell Phone Expert? Answer questions, earn points and help others
