No one can give you free unlock code. because each blackberry have different unlock code. As far as i know unlocking by codes is the simple and safe way.You will need the unique MEP Code for your Blackberry and to get it you can use a website with service for Blackberry unlocking .so you can use a website to Unlock your Blackberry Pearl 8100 online instantly - OR local mobile shop .they are mostly using cables to unlock it and the price is higher then on unlocking websites but the result is the same: SIM free Blackberry.
To get unlock code for free you need to request for the network unlock code from the carrier whom you have purchased the handset from,......
if you have the network unlock code follow the steps mentioned below to unlock the device
menu--> options--> advance options--> sim--> Press MEPD--> Press MEP2-->
The device will ask for the network unlock code and press on Ok..
First, you must describe your imei number and your network carrier information at your question if you want to get free blackberry 8100 unlock code. Second, a free blackberry unlock code is not guarantee can unlock your phone and work perfectly even in some case can make your phone hardlocked.
I dont know anyone that does this for "free" it takes quite a bit of our time to do it and we take quite a few risks.
SOURCE: free unlock of blackberry pearl 8100
Option # 3: T-Mobile or Cingular, your carrier
Yes, you can ask your carrier for an unlock code for your Blackberry and guess what, they do it for it Absolutely FREE. So, what is the catch? The only condition which atleast T-Mobile imposes on its customers before it gives out the unlock codes for the Blackberry Pearl or any other cell phone is that you have to be under the contract for atleast 90 days or 3 months before they can give you the unlock code. So, if you have the patience, I would recommend that you wait for this 3 month time frame before calling up 611 from your T-Mobile phone, talk to customer service and get your unlock codes.
In my search for the Blackberry Unlock codes, I found out that a lot of people mess up before they have no idea how to enter the unlock codes correctly. So, follow this method to enter your Blackberry Unlock code
How To Enter the Unlock Codes on a BlackBerry Cell Phone
Model : All BlackBerry Models (except T-mobile)
1 - Using the menu go to Settings Menu -> SIM card press select.
2 - While holding the SHIFT key, type MEPD or (MEPPD for Vodafone Handsets)
3 - You should now see the five locking categories listed.
4 - While holding the SHIFT KEY, type MEP2 or (MEPP2 for Vodafone handsets)
5 - Release the shift key.
6 - You are now prompted to enter the Network MEP code (it will also state how many attempts left)
7 - Enter the code
8 - Enter Return/Enter
9 - The device should then be unlocked
Model : T-mobile BlackBerry Models
1 - On the Home screen, click the Tools icon. The Options screen appears.
2 - In the tools screen, select the Settings icon.
3 - Scroll to SIM Card and select it. You should see the phone number and the SIM ID number.
4 - Type ‘mepd’ to display the first five levels of SIM locking.
T-Mobile uses network locking so the Network should display Active. All other states should display Disabled
Please note: For the Blackberry 7100t you will hit the “P” twice when entering the ‘mepd’ and ‘mep2′ for steps 4 & 5.
5 - Type ‘mep2′ to display the dialog box asking for the unlock code (Press the Alt + 2 key to get the number 2)
6 - Input the Network Unlock code
7 - Press ENTER and reboot handheld.
Model : BlackBerry Pearl 8100 (Alternative instructions if above instructions do not work)
Can be done without a sim card inserted
To Unlock:
1 - While on the home screen, click the “blackberry key” on keyboard, then select “options”.
2 - Choose “Advanced Options”.
3 - Select “Sim Card”
4 - There is no area to type these letters, you just type them as instructed. No need to hit keys twice to get a letter either. Type m e p p d to display the first five levels of SIM locking. Most companies use network locking so the Network should display Active. All other states should display Disabled ( you will not see text appear on screen
while typing )
5 - Type m e p p 2 to display the dialog box asking for the unlock code
(Press the Alt + 2 key to get the number 2) ( you will not see text
appear on screen while typing )
6 - Input the SIM Unlock code
7 - Press in the trackball in once
Your phone is unlocked
SOURCE: hoe to unlock Blackberry pearl 8100
It's a clear and fully detailed guide on how to unlock a BlackBerry pearl 81XX :
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (if your BlackBerry have touchscreen)
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 or MEP4 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter the mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the mep code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done.
SOURCE : BLACKBERRYMEP.COM
It's a clear and fully detailed guide on how to unlock a BlackBerry 8100:
3. Go to Options
5. Select SIM Card
8. Type MEP2 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter network mep code
11. Enter the code ( you should see "code accepted" )
All done.
