I have checked all wiring fuses are fine, also have checked starter motor works and repalced solenoid wired everything up by wiring diagram and still wont start there is power to the auto butterfly is switching on and of but there seems to be no power to the solenoid when i turn the key to start the starter motor
If you are sure that all connections are clean and bright, including the battery to the ground and battery cable to the solenoid, jumper from the battery (+) to the solenoid (+). If the solenoid clicks, but motor doesn't turn over, your solenoid is bad. Try jumpering momentarily from the battery (+) to the starter (+) and that should cause the starter to rotate. If that makes your starter rotate, your solenoid is still bad. Be sure that your starter has a good ground connection
