If the tanki is below the carburetor, there will be a very weak pump that pumps fuel to a small reservoir that feeds the idle & emulsion tubes. The pump is a diaphragm type that uses intake pulses to pull the fuel up and then a spring pushes the diaphragm back iin place.
If the tank is mounted higher than the carburetor, it will be a gravity feed.
Testimonial: "Thank you Tom that helped a lot"
