What do you think it the problems
There are really only two choices. Either the horn amplifier in each cab is blown, or the high frequency horn driver diaphragm is blown. It's easiest to check the diaphragm first. Open up the cabinet so you can get to the horn driver terminals. Put a voltmeter across the terminals and check for continuity. if it shows open, you've found the problem. Open the driver and replace the diaphragm and you're done.. If the horn driver tests good, it's time to take the cabinet into your local electronics repair place to have them check out the amp section.
