Somehow my Password does not open the tablet I have used the Password and tried voice but it closes down after about 3 or 4 seconds and refuses the password saying it is wrong
SOURCE: i need to download user manual for samsung galaxy
You can download the available documents from the following website.
http://www.samsung.com/uk/support/search/supportSearchModelResult.do?menu=SP01&searchWord=galaxytabpc&default_searchInputBox_value=Enter+model+number+or+keywords&searchInputBox=galaxy+tab+pc+
Please let me know if you require any further assistance.
Thanks
SOURCE: While playing a game, my
If holding down the power button for 10 seconds (theoretically, try holding it down for ages and be patient) doesn't reset your device, you may have to wait for the battery to run flat, then try the reset procedure again.
Hope this helps,
Alistair
SOURCE: SAMSUNG GALAXY TABLET NOT CHARGING OR TURNING ON
Hi buckpot2001,
To correct this issue, please follow the steps below.
1. Press and hold down the power button whilst at the same time touching the screen (you may have to wait up to 30 seconds as it clears the system).
2. You will then notice the battery indicator pops up.
3. The Tablet will then reboot. Everything goes back to normal.
4. If that fails to work, connect the power cable and repeat the above steps.
Hope it helps.
Thank you for using FixYa.
SOURCE: have a samsung galaxy tablet
Have you tried holding the power button for 10+ seconds? or can you remove the battery?
Testimonial: "thanks tried holding power button longer but it workede thanks"
SOURCE: Samsung galaxy tablet is frozen
Couldn't even turn mine off ... read up on this.
SIMPLE SOLUTION: Hold the power button down for more than ten (10) seconds. WORKED!!!!
