Minolta Dynax 404Si Film Camera Logo
A
Anonymous Posted on Aug 22, 2014
Wht is my film transport signal not visable on Minolta Dynax 404si?
Film transport signal not showing up
Jim Jordan
Level 3:
Master:
  • Minolta Master 442 Answers
  • Posted on Jan 06, 2015
Jim Jordan
Minolta Master
Level 3:
Master:
Answers
442
Questions
0
Helped
114928
Points
1360
If it will not work on any roll of film and you are sure the film leader loaded correctly and the film advances properly then the spring on the indicator or the indicator itself is defective. Only option is to try and open it yourself if you're daring or send it in for repair.
2 Related Answers
Anonymous
  • Posted on Dec 18, 2008
SOURCE: remote cord for minolta dynax 404si
Best place EBAY but you might have to try different country like UK or CANADA also check the web page of the person doing the listing.More than likely this is the place to find it .I have seen one recently in this location.
k24674
  • 8093 Answers
  • Posted on Sep 11, 2009
SOURCE: what kind of film do I need?
Use the regular 35 mm films, if you can find them.
Hope it helps.
2helpful
How do I change from panaramic to full photo
Push the square button next to the top display panel.
1helpful
What kind of film do I need?
Hope it helps.
1helpful
Can't get the film to catch trying to load.
I found a manual online that gave the information.
Zoom
Generally when a camera refuses to take the photo is because you are operating beyond its expected lighting settings. If you are on automatic, it will just flash a light at you, or give you some indication it is beyond the limits of that setting. Try manual, or some other setting like landscape, or backlight. Generally this will happen on automatic settings.
Film? Try the f16 rule. In broad daylight, the rule is use f-16 and a shutter speed that matches your film's asa. So 100 ASA film? Shoot the sunset at 100th at f-16. Darker, open it up two or three stops. f-11, 8, or 5.6.
Bottom line, make sure you are on manual. The problem is likely an automatic exposure.
Remote cord for minolta dynax 404si
Minolta Dynax 404si
You will find a copy of the owners manual available from the website link below
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/index.html
Yes the camera has a built in light meter the manual will explain how you can use it
Top Minolta Photography Experts
ZJ Limited
ZJ Limited
k24674
Are you a Minolta Photography Expert? Answer questions, earn points and help others
