Oster Turbo A5 2-speed Dog Pet Clipper 10pc Comb Guide Logo
p
peter vickers Posted on Jun 21, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The brand new gear lever on my oster a5 isnt moving the clipper blade
The brand new gear lever on my clipper is not moving the blade when turned on
Anglia Clipper Services
Level 2:
  • Expert 193 Answers
  • Posted on Aug 14, 2014
Expert
Level 2:
Answers
193
Questions
0
Helped
83677
Points
240
Make sure the blade is clicked into place fully, secondly check to see if the blade is sitting further away from the clipper than usual, it could also be a stripped gear inside the clipper does the lever move when the blade is engaged?
Oster problems. Golden a5 clipper
The blade driving lever is certainly supposed to move, if it isn't then take the cover off and check the cam gear, it's really easy to change it.
1helpful
A5 dog clipper or blades may need tune up or
some times the link and gear inside the front part of the clipper wears out and the blades just wont cut. try this, remove the clipper blade on the front of the clipper their is a lever color red grab this part with your 2 fingers and move it side to side if it moves and feel sloppy your gears and link are worn out. you need to replace, also check the hinge for spring tension. if you need help Contact [email protected]
2helpful
Oster A5 clippers are slow and vibrating noisily even without a blade attache. Any ideas what could be wrong with them please as I have a dog only half clipped at the moment. Thanks
If the nylon lever (the tab that moves the blade back and forth) is not moving with the blade off, or only moving sometimes, chances are that you have a stripped bakelite gear. Take the two screws out of the cover plate and remove it. Remove the lever (the nylon part that moves the blade) Remove the link (the metal part that the lever connects with). Remove the bakelite gear (the part that the link fits down over). You should then be able to see if the teeth are chewed or worn off to the point that the armature gear will not turn the bakelite gear. If that is the case, replace the gear. Amazon carries both single speed and 2 speed gears under Oster A5 clipper parts. All these parts should have a light coat, where they move, of lithium grease, and the two pads (one on each side of the lever) should be oiled. You might also check the condition of your brushes (under the caps on each side of the clipper. Take cap off, remove cover from brush, remove spring and brush to see how worn they are).
Good luck.
6helpful
2answers
Bought Oster Golden A5 clippers new but did not
There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Terms regarding these devices are all too often assumed as understood. For most purposes, these are what you have to know for the A5 Oster. The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device. The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). That gear is turned by the armature gear of the motor (which is where things get much too involved to cover here, but from that point on the device very rarely has problems). Incidentally, the lever, the link, and the gear can all quite simply be replaced. They are available quite inexpensively at Amazon under Oster A5 Clipper parts (note that the one speed and the two speed take different bakelite gears, but the lever and the link are the same). If you were to replace parts such as these or simply lubricate them, remember that a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear). Also, the gear shaft has a hole down its middle (and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The two pads (one on each side of the lever) should be oiled. The simple way to tell if you need to replace parts is to grip the blade end of the lever while all parts are in place and try to move it back and forth, as though it were running the blade. If there is any more than the slightest movement, replace the lever (replace that anyway if the part that contacts the blade is rounded off) link and gear.
Good luck.
1helpful
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Fixable A5 Clippers?
If the power lever (the tab that moves the blade back and forth) is not moving with the blade off, or only moving sometimes, chances are that you have a stripped bakelite gear. Take the two screws out of the cover plate and remove it. Remove the lever (the nylon part that moves the blade) Remove the link (the metal part that the lever connects with). Remove the bakelite gear (the part that the link fits down over). You should then be able to see if the teeth are chewed or worn off to the point that the armature gear will not turn the bakelite gear. If that is the case, replace the gear. Amazon2.gif carries both single speed and 2 speed gears under Oster A5 clipper parts. All these parts should have a light coat, where they move, of lithium grease, and the two pads (one on each side of the lever) should be oiled. You might also check the condition of your brushes (under the caps on each side of the clipper. Take cap off, remove cover from brush, remove spring and brush to see how worn they are).
Good luck.
1helpful
2answers
My A5 clipper is not clipping at all.
If the blade mover is going when you turn the clipper on than all you need to do is take the blades apart and clean them well with a Oster spray and then oil them. I would recommend cool lube.
Blades do not function
If the power lever (the tab that moves the blade back and forth) is not moving with the blade off, chances are that you have a stripped bakelite gear. Take the two screws out of the cover plate and remove it. Remove the lever. Remove the link (the metal part that the lever connects with). Remove the bakelite gear (the part that the link fits down over). You should then be able to see if the teeth are chewed or worn off to the point that the armature gear will not turn the bakelite gear. If that is the case, replace the gear. Amazon carries both single speed and 2 speed gears under Oster A5 clipper parts.
Good luck.
2answers
Oster A5 pet clipper-not sure what the part is called, but the piece that pivets back and forth is not moving but the clipper is making noise.
If the power lever (the tab that moves the blade back and forth) is not moving with the blade off, chances are that you have a stripped bakelite gear. Take the two screws out of the cover plate and remove it. Remove the lever. Remove the link (the metal part that the lever connects with). Remove the bakelite gear (the part that the link fits down over). You should then be able to see if the teeth are chewed or worn off to the point that the armature gear will not turn the bakelite gear. If that is the case, replace the gear. Amazon2.gif carries both single speed and 2 speed gears under Oster A5 clipper parts.
Good luck.
Top Oster Pets - Others Experts
Kardoc
ADMIN Andrew
ADMIN Andrew
Sierra
Sierra
Level 1 Expert
Are you an Oster Pets - Other Expert? Answer questions, earn points and help others
