open the keypads, and clean with contacts cleaner, from dirty, oxide, corrosion, clean the contacts batteries , and replace by new ones. see the diagram use digital camera, the LED must be TURN ON. resolder any colder joint. God bless you
Turn it off remove the battery get a spray bottle fill it with destilled water turn the keyboard upsidedown over a clean towel spray the keyboard till it drips clean;meaning the drops of water are clean. When finished spraying, Dry with a hair dryer for 30 minuts on low heat let set on clean dry towel for 12 hrs Check for resisual moisture. If any repeat drying proceedure. let set another 12 hrs on clean dry towel
till dry replace battery fire that muther up
way simpler tham removing the keyboard and cleaning it.
best of luck
Here is reference to one of the best blogs I have found online for disassembling the KS Pro 88, because this one includes photos.
http://ratula.net/eblo/archives/000438.html
Best regards,
JSR
Start Button-->Recovery(type this in the start search)-->click on Recovery manager-->click on advance option tab-->select Hardware driver reinstall option and click next-->select the option for audio driver and click next-->again click next-->after teh reinstallation completes restart the Laptop.
Sadly, not too much can be done. You COULD try to get in there with a small tool and bend them back, but I don't know how extensive then damage is. If you really know what you are doing, you could find an old device with a USB port on it, de-solder that port off, and solder it onto the keyboard. But If you try that, I really hope you know what you are doing. If not- time for a new keyboard. Or- get yourself a USB 2.0 hub and place it next to your keyboard. I have one stuck to the side of my PC with velcro tape.
Computer Cleaning Information
Procedure: The plastic case that houses the PC components can be cleaned with a ... Procedure: Many people clean the keyboard by turning it upside down .
