Try restarting your iPad. To do this, simply press and hold the Sleep/Wake button until a red slider appears; then slide the slider. To turn back on, press and hold the Sleep/Wake button until the Apple logo appears.
If tip above does not work, try resetting your iPad. To do this, press and hold the Sleep/Wake button and the Home button at the same time until you see the Apple logo.
If above tips do not work, the issue could be that the battery is fully depleted. Plug it into a wall outlet for a while and see if your battery holds a charge. Please note that it can take up to 20 minutes of charging before the iPad will start up.
You are able to move the books to computer, and then sync ebooks to iPad with iTunes. When the Kindle users connect their Kindle tablets to computer with the USB cable, their computers will recognize their Kindle tablets as external hard drives. Then the users can copy and paste the ebooks from Kindle to computer easily. After that, the users are able to sync the books from computer to iPad with iTunes.
This is easy to be done. But when users begin to sync their iPad with iTunes, they may come up with the sync problems of iTunes. The problem may come up when users sync ebooks from iTunes to iPad. During the sync, iTunes will erase all the non-purchased items in your iPad mini. If you are new to iOS devices, you will probably lose files during the sync with iTunes, so you'd better close the auto sync and manually sync the ebooks to your iPad mini with iTunes. The following tutorial will be helpful if you aren't sure about how to accomplish the task:
Start iTunes and go to "Edit > Preference > Devices", and check "Prevent iPods, iPhones and iPads from syncing automatically".
Plug iPad into computer via USB cable, and the software will recognize your iPad and display the iPad icon at the upper right corner.
Click the iPad icon and choose "Books" in the summary panel. Choose the books you want to sync to iPad in the list below, and click "Apply" to start.
Are you using the charger that came with it? The charger needs to be at least 10watts. A charger meant to charge iPhones or iPods will cause this kind of problem.
First thing to do would be to connect it to your computer with the cable supplied and allow it to charge. You can download a manual from http://support.apple.com/manuals/#ipad Hope this helps
All you do is turn off the touch sounds and screen lock sounds then you go to the sound and press the mute button I'm 11 my ps3 user account is a NEXION218 all capitals OK well that's it ask me any other questions I have the solution
You should be able to find your user guide at http://www.theipadguide.com/faq/where-can-i-download-ipad-user-manual-guide which also includes a link to display the manual for your iPad ON your iPad automatically.
The instruction manual is on the ipad web site at Apple.
It's always a good idea to look at the websie of the manufacturer before posting a question here.
That's what I do when I answer them!
